3-Point Hitch L185 hydraulic lift not woking right
   / L185 hydraulic lift not woking right #1
morris lipham
Bronze Member
prattville al
kubota L185, yanmar YM1700
used tractor in oct. to plant green field and replaced woods belly mower after and everything worked fine. started up again in march and lift lever would not budge,I screwed lift speed knob in and out and it would raise half way ,but much harder to move lever. I cut about a half acre and checked fluid level again and it looked like it had sucked air into fluid. I let it sit a week and checked fluid again and it looked clear again.
Thanks hunterridgefarm, thats what I was hopeing. I bought a new filter and I will change hydraulic fluid and filter this weekend. I bought this tractor used in 1996 and have used it to cut 7 or 8 acres every weekend during grass growing season with no problems. I put woods belly mower back on this year right after planting foodplot and left 3pt hitch up a little and I think that caused the problem.I usually leave off any equipment and hitch lowered all the way down.
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2014 STEPHENS CRUDE (A50854)
2014 STEPHENS...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2015 Freightliner Cab & Chassis (A47384)
2015 Freightliner...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
