L210--too weak?
   / L210--too weak? #1
Anonymous Poster
Epic Contributor
I have an L210 Kubota (21 HP). The bushhog (Mohawk)is 5' and does fine in thin grass. In the thicker stuff it just bogs down. Do I need to size down, or is there a hog (rotary cutter) that might do better? Blades are fairly sharp, and I'm going pretty slow. The main problem grass is Bahaya (sp)?
   / L210--too weak? #2
Murph,
You're probably a little above the best size for a 21-horsepower tractor - 4' is most common unless you have a very light duty cut to do, then 5' might work to a certain extent. But if you can justify it, sizing down to a 4' cutter would likely make some difference. In your case, you might want to try before you buy, if possible.
   / L210--too weak? #3
Don't know what "Bahaya" grass is, but I agree with Muhammad. When I had a B7100 (16hp), it was a fine little machine, but tall thick grass, fire ant mounds, etc. sometimes bogged it down a bit even with the 4' brush hog. Sounds like you need to downsize the cutter, upsize the tractor, or go very, very slowly./w3tcompact/icons/smile.gif
Bird
   / L210--too weak? #4
<font color=blue>Don't know what "Bahaya" grass is</font color=blue>
I was going to ask the same thing... ???
   / L210--too weak?
Bahaya is a FAST growing TOUGH grass that some people use for hay here in SW Arkansas. But get it in your yard and it's a real pain in the ___. I don't know if the spelling is correct, but it's pronounced that way. Also, it has a long tough stem with seeds growing out the top on little stalks. Anyway, thanks for the replies, also thanks to Mohammed.
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2011 CATERPILLAR 259B3 SKID STEER (A51242)
2011 CATERPILLAR...
1999 Toyota Camry Sedan (A50324)
1999 Toyota Camry...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A52128)
Adams FL24...
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
