L2501 vs BX vs B
   / L2501 vs BX vs B #11
I have ag tires and use a land pride 60" finish mower with gator blades
   / L2501 vs BX vs B #12
Saw a few comments on "not to mow". What specifically does the L2501 lack to drag a 4-5 bush hog?
Would you select a B2620, why it over an L series?
L2501 omits the mid-PTO so you cannot operate a Mid Mount Mower, you have to mount some form of Three Point Hitch mower. Those who do woods work prefer not to have vulnerable, forward-facing mid-PTO.
L2501 is supposed to operate a 60" Rotary Mower. I speculate that grass should not be too long and the blades kept sharp to provide a quality cut with 25-horsepower.
Allowing for a 6" overlap, a 48" Rotary Mower cuts a 42" swathe.
Allowing for a 6" overlap, a 60" Rotary Mower cuts a 54" swathe; 28% increase.
To mow longer grass consider a L3301. Same tractor as L2501, one increment more powerful engine.
Tractors with 12" to 14" ground clearance will provide a less violent ride over pasture, relative to BX size tractors with 9" ground clearance. The larger wheels/tires bridge more holes and ruts.
B2650 26-horsepower from 77 cubic inch engine, 1,786 pounds bare tractor.
L2501 25-horsepower from 100 cubic inch engine, 2,623 pounds bare tractor. A significantly more capable machine.
I spreadsheet data on tractors I consider purchasing.
These are residential tractors. Most operators adapt to the size within an hour.
If you PARAGRAPH your posts, especially when you open a thread, they will be more comprehensible to your readers and you will receive replies of more value to you.
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2009 Ford F-150 Ext. Cab Pickup Truck (A55973)
2009 Ford F-150...
2022 Horizon Trailer (A55973)
2022 Horizon...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
55-Gallon Drum of 50/50 Antifreeze Star Fire Pure Fleet Red Heavy Duty (UNOPENED) (A59076)
55-Gallon Drum of...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56436)
PENDING SELLER...
