L2800 Position Control (Jerky?)
   / L2800 Position Control (Jerky?) #81
It's funny to me that knuckle-bota calls it "position control". I don't know exactly what "position control" is but those jerky valves are the farthest thing from having ANY kind of control over the 3ph. Attaching implements... you can not ease the 3ph into an "exact" spot during the raising up mode. You learn to bounce the 3ph up close to where you need it... then over shoot your mark... then lower to where it needs to be... repeat as many times as needed. :D
   / L2800 Position Control (Jerky?) #82
It's funny to me that knuckle-bota calls it "position control". I don't know exactly what "position control" is . :D
What position control means is that the 3PH follows the control lever. If you put the lever on a certain number the 3PH will always go to the same place. Without postion control it works more like a loader. This is very handy if you want an implement to go the the exact same height each time you use it.
On the L3400 the spot is good to 1/4" instead of exact. As you mention, you can drop it a tiny bit to get to a more exact point. This is a real pain. It is still a position control though. For me, 1/4" is fine for the mower.
   / L2800 Position Control (Jerky?) #83
Goog: Is your valve perfectly smooth? can you make it move up, say 1/32 of an inch? My 1910 is perfectly smooth but not my L3400. It moves about 1/4" at a time but it does not jerk badly, just a little. It is pretty much just a fairly smooth 1/4" jump.
No it is not perfectly smooth and moves up in 1/4" increments as others have said. But compared to how it was I darn glad to gat it. Infinite adjustment would be awsome but not going to happen on these tractors. Brian
   / L2800 Position Control (Jerky?) #84
How does the 3PH on the L4400 tractors compare to the L3400/L2800? Is the L4400 super jerky like the original L2800/L3400 valves, 1/4" jerky like the improved L3400/L2800 or smooth like the GL or JD790? Just curious.
   / L2800 Position Control (Jerky?) #85
Just curious, are there any engineers or hydraulic pros following this discussion that understand why this valve works the way it does? I'd really like to know if there is a reasonable solution to this problem.
For example, would it be possible for a good hydraulic shop to gut my valve and rebuild it with better components to get similar performance to the JD790 in the video posted earlier?
Or, is there a plausible way to retro fit a better valve than the upgrades Kubota has offered/installed?
I want to make sure we're not all upgrading to better machines; fighting with Kubota's, dealers, reps and customer satisfaction department; and consulting lawyers to avoid a $400 trip to the local hydraulic shop. I'm sure a lot of people don't feel they should have to spend another nickel, me too but for the trouble, I want the best option available to me.
   / L2800 Position Control (Jerky?) #86
I would pay $400 to have mine working good. It would be a whole lot cheaper than upgrading tractors. I don't think there is a simple cheap fix though. It's been asked several times on here if anyone knew of a fix and no one has replied. Besides it's normal. It is an ECONOMY tractor after all.
   / L2800 Position Control (Jerky?) #87
...an ECONOMY tractor after all...:rolleyes: :confused: :( :mad::mad::mad::mad::mad::mad:.
What we need and will not get is information from a good kubota dealer, they most likely know the answer. Thanks, dealers... I'm guessing if a kubota dealer talks all heck will break lose. I really wonder if "headquarters" would even allow those valves to be sold. Maybe against "company policy".
I would not recommend buying an L2800/3400 since the reputation is tarnished and you don't know what you are actually getting... smooth move kubota for changing the valve back and duping a few more "customers". What do you have planned for the other tractors models?
   / L2800 Position Control (Jerky?) #88
Yep, a little help would go along way. I'm not yet convinced that there are not other L series valves that would be an easy fix but the specs. are so closely guarded... there is still some cross referencing I can still do but without help, installing another valve is just an experiment.
I bet I could get to the bottom of this if someone let me into that computer behind the parts counter. Actually, access to the parts would be even better.
Broken record, I'm pretty sure Kubota DOES NOT want this tractor to have a smooth 3 pt.
My latest thought, is the L3010 valve smooth on the L3010? If it is, we're all missing something.
   / L2800 Position Control (Jerky?) #89
Harvest Moon - good thoughts. I'm sure it is not rocket science to make a 3PT valve that is actually smooth.
Pretty much every other tractor has one. I think it will take a L2800/L3400 owner who actually knows enough about hydraulics to rip into his tractor and try to retro fit.
The 'fixed' valve works good enough for me even thought it is not exactly what it should be. I decided that it was not worth upgrading tractors to me because when I upgrade I want a cab and I would loose too much money in depreciation.
Once you put a few hours on your new machine it is used and it has already done the depreciation that it is going to do for me for the first 5-7 years at 50-60 hrs a year. In Canada we pay a lot of sales tax as well so the hit you take on sales taxes if you are buying new every few years really hurts. I pondered trading in my machine and would have done it but the dealer literally offered me 45% less than I paid for my machine when it was 1.5 yr old and had 75 hrs on it..
FWIW, I really have not found anything that I could not do. It may well be the case that I'm really not that good at box-blading anyway but at my level of skill, its not the tractor's performance that gets in the way at all. I've done a little of everything too - quite successfully - box blading, digging post holes, landscape rake, bush hogging, snow blowing etc. etc. More than anything else it is just an irritant and a reminder that I would have preferred to not have the 'economy' tractor.
   / L2800 Position Control (Jerky?) #90
In post #43 of this thread, I posted the pages from the parts manual for the 3ph valve. One page is titled "Old Valve" and has two different part numbers with serial numbers. The other page is titled "New Valve" and shows still a different part number. Can anyone cross reference these numbers to the L3010.
Terry
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A55973)
2009 Sterling...
JOHN BLUE 1000 GALLON NURSE TANK (A52708)
JOHN BLUE 1000...
PALLET OF MISC CERAMIC TILE (A58374)
PALLET OF MISC...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
HOMEMADE STRIPE BOAT (A52708)
HOMEMADE STRIPE...
2015 CAT D5K2 LGP (A55272)
2015 CAT D5K2 LGP...
