L2800DT & L3400DT vs Kioti CK30 HST
   / L2800DT & L3400DT vs Kioti CK30 HST #1
CajunRider
Platinum Member
Cajun Land
Kioti DK45
I was about to go for the CK30HST when my Kubota dealer told me about the 2005 HST on the L2800DT and the L3400DT. The specs are really close on these 3. Has any one here had a chance to try out the L3400HST yet?
   / L2800DT & L3400DT vs Kioti CK30 HST #2
I haven't tried one, but the CK30HST remains heavier, has more ground clearance, only slightly higher gpm on the hydro flow, a little wider stance, Maybe a little longer (Kubota is measured w/o 3pt at 106" the Kioti 122.2" including 3pt), longer wheelbase etc.
I'm sure the Kubota is a wonderful tractor, but be sure you count all the things offered on the Kioti that are extra on the Kubota such as the joystick and valve for a loader. The Kubota also doesn't have telescopic hitch arms as does the Kioti, but has the telescopic sway bars. I also prefer the sloped hood and loader arms of the Kioti over the square view one gets with the Kubota. The platform operator's station on the CK30 is more comfortable to me. Kubota's specs don't give the HST traveling speeds,so can't compare that. The Kubota comes out ahead with a slightly higher engine and PTO HP, but the lighter frame may make them about equal.
I think you'll find that the price difference may favor the CK30 as there isn't enough difference to make buying the Kubota a better choice in my opinion.
If you're comfortable with the Kubota over the CK30, then by all means, that's the one to buy.
Do what I did, take pictures of the rears of both tractors, and of the fronts and sides so that you may compare them at home. John
I agree with you, the CK remains a strong candidate for me. As for dealer support, I have plenty of Kubota around me. The nearest Kioti is in the next town but with today's internet shopping getting parts is really not a big issue.
New/Unused IRGC40 Mini Golf Cart (A57453)
New/Unused IRGC40...
2020 CATERPILLAR 299D3 XE SKID STEER (A52709)
2020 CATERPILLAR...
JOHN DEERE 6615D MFWD TRACTOR (A52708)
JOHN DEERE 6615D...
Toro Dingo Mini Skid-Steer Mounting Plate (New/Unused) (A59225)
Toro Dingo Mini...
2022 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
2014 Freightliner 108SD Truck, VIN # 1FVHG5CY3EHFL1495 (A57453)
2014 Freightliner...
