L3010Ken
Not sure if this is the right place for this question . . . I have been a long time lurker but not much of a poster.
I have noticed a very slight amount of UDT fluid leaking from somewhere on my left front axle and have kept my eye on the fluid level over the last 20 hours of operation (about the last 3 months as it didn't get much use this winter) and the fluid was full at all times. Last weekend I brushhogged about 5 acres and when I pulled the tractor up to the shed I noticed quite a lot of oil on the tire -
YIKES!!!
I cleaned everything up and let it sit until today so I could find definitively where the oil was coming from. When I looked at it this morning, it was pretty clear that it was the hub seal. I bought a seal and bearings from the local Kubota dealer and started the teardown.
A LOT of metal came out which was kind of a surprise. . .
The inner bearing and gear came off with a small pair of pry bars (aka screwdrivers) with little effort - a tight slip fit.
The outer bearing was toast - I am sure I have overloaded the front axle hundreds of times with the Woods Loader - this doesn't look good.
Getting the seal out was pretty straight forward - just pry up around the perimeter.
The bearing came right out with a couple of taps with a drift around the perimeter of the outer race. I wasn't too concerned about damaging it.
The inner bearing appears fine, no brinneling / it turns smoothly. I also inspected the ring gear and there are no marks / indents from shrapnel on any of the gear teeth.
I am concerned about the lower pinion gear / bearing as this is where gravity would send the fine bits of metal that spalled off of the bearing race and whatever chunks of the race that might have made there way down into the lower drive shaft support bearing (part # 130 in the photo below) . . . if I pull the lower cap (part # 110 which is not leaking now) - can I reinstall it and still get a good seal?
I am thinking that I should just go ahead and replace the lower bearing while I have it this far apart. I own a good set of snap ring pliers - and this lower bearing appears to be the same part # as the inner bearing that I already purchased but didn't use . . . Any thoughts on this?
Lastly - the dealer said that I could replace the UDT in the front axle housing with 80/90 WT gear lube. I have a 5 gallon bucket of SAE 80W90 Chevron Multigear EP-5 that I bought for my dozer . . . I know there are concerns for using this in transmissions with bronze / synchro parts but would it be ok to use this in the front axle?
Thanks for any reply.
YIKES!!!
