L305 Dt 4WD specs ?
   / L305 Dt 4WD specs ? #1
John_Mc
Elite Member
Monkton, Vermont
NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
My uncle is looking at an L305 DT 4WD (so far, looking by email and phone calls, has not laid eyes on it). I've been trying to dig up some specs on it for him. So far, all I've got is what's on Machinery Link (basically, weight, HP and transmission).
Can anyone point me towards more detailed specs? Would like info on length, wheelbase, etc. Also, if you could compare it to whatever is the closest current Kubota offering, that would be helpful.
Thanks .... John Mc
   / L305 Dt 4WD specs ? #2
Kubota L305 –2WD version
TRACTORS from KUBOTA
Model = L305DT 4WD
SPECIFICATIONS
Years Mfg: 1980-1986
Fuel: D
Engine Make: KUBOTA 3-CYL
CID: 79.3
Engine HP: 26.2 PTO
30-E
Cab: ROPS
No.Speeds: 8/2
Weight(Pounds): 2,985
List Price: $11,120
PRICING
Year Ad Price Est.Loan Value
1980 $3,757 $2,480
1981 $4,268 $2,817
1982 $4,833 $3,190
1983 $5,477 $3,615
1984 $5,652 $3,730
1985 $6,297 $4,156
1986 $6,722 $4,437
Auction Results:
MAKE YEAR&MODEL COMMENTS/CONDITION STATE PRICE
KUBOTA L305 D/F MO $3,000.
KUBOTA L305 D/G OK $3,000
~~~from the web~~~
Thanks, JM3. Sometimes a picture is worth a thousand words.
Intended use is for bush hogging, and some earthwork (w/ FEL, rear blade, box blade, etc). Any idea whether this would be a decent platform for a backhoe? He needs something in the size range of a Woods 7500 or similar. Is a 3 pt hitch BH OK with these models, if used with care, or should he be looking for a subframe mount? (If subframe, can you even get the subframes anymore to fit an L305 ?)
Thanks for any comments.
John Mc
   / L305 Dt 4WD specs ? #4
I've owned a 305DT since '83, when I bought it new. I've done alot of brush hogging with it, but when mowing heavy grass or brush, it's a bit under powered. That's the reason I purchased a used 61HP John Deere for that purpose. The extra HP lets it breeze through the brush, and it's a lot easier on the tractor. You have to continually watch the engine temp on the Kubota to make sure it doesn't overheat. Fact is, that's what that white bottle is for on the other gentleman's picture post. It has the overfill tube in there to catch the radiator fluid.
I don't have a FEL on mine, but I would think that it would handle it OK. I made up a 10" steel "I" beam bumper to deflect trees and brush when mowing.
As far as a BH goes, I own a JD 410 and don't use an attachment on my Kubota. It would probably handle a small BH attachment.
The 305DT has been a good tractor for most of my other applications - except heavy brush hogging.
John
John - NY
Thanks for the info. I assume you were using a 5 ft brush hog with your 305? That's what my uncle will probably want to use. (If it had trouble with a 4 ft unit, then I'd say it's seriously underpowered for it's frame size.)
John Mc
   / L305 Dt 4WD specs ? #6
John,
Yes, my "brush hog" is a 5' Woods Brush Bull. I used a Brillion "chopper" for years before I purchased the Woods model last fall. That was a little lighter, but I still had overheating problems in thick vegetation. It was fine for most other applications.
John
Thanks for the help, John in NY and JM III!
My uncle got beat to the punch... the tractor was gone by the time he called to arrange to see it. Back to the drawing board.
John Mc
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
Skidsteer Wheel Tracks (A59814)
Skidsteer Wheel...
2003 Big Tex 10PI...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2014 GMC Sierra SLT 4x4 Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
