L3130 HST 4WD question?
   / L3130 HST 4WD question? #11
Had the same problem with my L3430. Came out about two quarts short. The listed capacity must be wrong.
I am due for the 400 hour axle change soon. I will carefully drain and see what it will hold. I use Kubota 80w-90 Gear Oil.
ksmmoto
   / L3130 HST 4WD question? #12
I had the same thing happen to me. It only took about a gallon to fill the front axle on my L3130. I too, was wondering about this.
Curt
   / L3130 HST 4WD question? #13
My L3130HST had 90w gear oil in it.
Also have extra quarts of it like everyone else.
   / L3130 HST 4WD question? #14
Penokee
Just like you, I could only get around 4 qts of UDT in the front axle case. I put the tractor in 4wd, raised the front end, tilted the axle and drained each side for around 2 hrs each. Looks like the manual may be off, or we cannot get all 6 qts out using the drain plugs.
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
2013 Haulotte 4527A (A57148)
2013 Haulotte...
John Deere 4600 (A53317)
John Deere 4600...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
2015 MACK CXU613 TANDEM AXLE SLEEPER TRUCK (A59575)
2015 MACK CXU613...
