L3130 sometimes won't start then just starts fine
   / L3130 sometimes won't start then just starts fine #1
Builder Mark
I've got a l3130 with about 115hrs on it. Recently (this season) it will not start. It will turn over just fine but it seems like it isn't getting any fuel, then at random times it will just start right up and runs great. I thought it was the safety seat switch or maybe a fuel relay or something. The fuel filter and line are all clear. I hate to take it to the local dealer if it is something small. Any and all tips would be great!
   / L3130 sometimes won't start then just starts fine #2
How cold is it where you are at? Could it be the fuel is gelling and it starts when you try again when it's warmer? This would explain why it runs well after it starts.
   / L3130 sometimes won't start then just starts fine #3
If it cranks, it's probably not a safety switch.
   / L3130 sometimes won't start then just starts fine #4
John is right here but it could be the electric fuel shut off switch. Kubota diesels are one of the best starters out there and if you have fuel getting to the pump, it should start!
A safety switch will not let it crank to begin with!
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2019 KENWORTH T680...
167 (A52708)
167 (A52708)
40ft High Cube Shipping Container (A57453)
40ft High Cube...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
150 Gallon Fuel Tank With Gate Valve (A56860)
150 Gallon Fuel...
Metal Bison Statue (A57454)
Metal Bison Statue...
