Some observations about changing the "11 gals" of UDT and both filters...
1 - Its probably obvious, but removing any back-hoe or 3 point implement and even the 3 point hitch gear, makes it a lot easier to access the transmission drain plugs with 5 gal buckets AND the transmission dip stick / filler.
2- You can raise the rear of an L3240 enough to get a standard 5 gal bucket under ALL drains buy driving over a single 2X10-12 with the rear wheels.
3 - I used the FEL to raise the front of the tractor to level it and let it down on 2 2x10s due to the sloping ground.
4- The two drains on the rear axle dumped less than 2 gallons total (e.g. about 3/4 gal each).
5- The center drain on the tranny dumped the rest (nearly 8 gals), requiring me to re-plug the drain when my 5 gal bucket was nearly full. This is very messy. I had a drip pan under the 5 gal bucket to catch the run off UDT while I blocked it's decent into the 5 gal bucket and re - inserted the drain plug.
6 - I only recovered approx. 9 gals of UDT even though I allowed all drains to run till they were "dripping". It took just under 10 gallons to re-fill after running the engine a few minutes to fill the filters.
7 - Thank goodness the "suction filter" has a magnet which captured 2 large pieces of shrapnel and lots of fine metal debris
8- The filter on the left side took forever to unscrew because the threaded part of the filter housing nearly unscrewed with the filter
I screwed it back into the housing prior to installing the new filter.
9 - I used a brand new flexible funnel (w/ screw on lids to keep it clean) to access the UDT fill port.
10 - The sharp threads in the UDT fill port can severely scar a flexible funnel to the point of potentially dropping little bits of plastic into the tranny and hydraulics
11- You really can't use the capacities listed in the manual to determine how much UDT etc. to purchase/install. They may be the amount required when completely dry. But the drain plug design/locations do not allow fully draining anything I've tried so far
Talon Dancer
