L3250 has some new paint
   / L3250 has some new paint #1
rbargeron
Elite Member
MA
L5450, L48, L3250, L345
I bought a fixer-upper L3250 a couple years ago. Runs great but was a bit ugly. This summer I decided to paint it. Jay4200's tip about Lobster Red came at the perfect time. Took off the most rusted parts for sandblasting & priming. A HVLP sprayer worked well with factory Orange II paint on a lot of it. But between the sheet metal and the loader there are a ton of surfaces. So the rattle cans made a big difference for doing small areas and missed spray directions. The color match is good enough I can't tell anymore which is which. The wheels had been replaced at some point so didn't need doing. If you are thinking of doing a tractor paint job, it takes longer than I thought it would. But from 10 feet away it looks decent.
   / L3250 has some new paint #2
Huge improvement. Looks good!
   / L3250 has some new paint #3
Came out great!
   / L3250 has some new paint #6
Looks great. Now if we could only buy Lobster Red in quarts I would be happy.
Regards, Fred
   / L3250 has some new paint #7
Nice work! You got new decals from ???
   / L3250 has some new paint #9
I know the struggle of it not being easy I started the beginning of the summer and I'm not nearly close to being done
   / L3250 has some new paint #11
very nice job, I am picking up a fixer upper B7800 next week and may use the info.
   / L3250 has some new paint #14
It looks great. The colors most likely to fade are yellows, reds, and oranges. From your signature line, it looks like you have your work cut out for you keeping up with fading paints.
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A61307)
2019 Krause...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
15200 (A56857)
15200 (A56857)
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2015 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2015 FREIGHTLINER...
