L3300 slipping
   / L3300 slipping #1
dirt clod
panama city and altha florida
Kubota L3300, m5700, case 580se
My l3300 gst I 1st noticed the clutch pedal was a little harder to push in . Thought something may just be sticking so I continued to use. Now the tractor will not move when under load and barely by itself. I do not smell a burning smell or anything hot when slipping. To get it home when it would stop I could get it moving again by pushing in clutch and letting off. What could this be, clutch pressure plate?
   / L3300 slipping #3
Is there a cover to look in and see whats up.
Usually the clutch gets spongy before it go's
The pressure plate can just go.
I would suggest posting in the kubota forum for more responses.
tom
   / L3300 slipping #4
Just guessing, but could the throw out bearing be sticking on the input shaft?
Is the trans full of fluid? (GST)
   / L3300 slipping #5
Is the clutch real easy to push or does it feel normal?
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
2016 Toro Groundsmaster 4500-D 4WD Commercial Rotary Mower (A59228)
2016 Toro...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(1) 48"X15' ADS DRAINAGE PIPE (A60432)
(1) 48"X15' ADS...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
