I wonder if you have a herd of algae running around in the fuel tank and everytime you try to move it sloshes it enough to close the inlet screen?![]()
hes not moving it, hes simply depressing the clutch. and it revs back up if he depresses the clutch
ya know, on my 4400 i can HEAR the fuel solenoid "click" when I turn the key on, then I hear another "click" when I turn the key off...... IF his tractor is the same, stands to reason he should be able to listen for the audible "click" when he starts releasing the clutch pedal...... this would tell us if its an electrical safety switch issue, or if its something else!!..
OP, Did you try releasing the clutch with the trans. in neutral, if so, what was the result?
I guess I wasn't clear enough on my first post. If pto is disengaged and trans in neutral, it doesn't die. I had to move my son across country the last few days so I haven't had a chance to look at it closer. Only when I have it in drive does it die.
