L3400 Float Control
   / L3400 Float Control #11
It won't if the 3pt frame will not rotate fwd/aft and if the tail wheel does not have weight on it.
The frame does rotate forward and backward.
   / L3400 Float Control #13
The chains I was referring to took the place of the toplink, I think. It's been quite a while since we used them.
   / L3400 Float Control #14
Funny my mower deck is set up quite similar to yours , I have a set of chains that run from the mower deck to the top link , and the 3 point saddle pivots on the deck with pins , it will float with the ground some what .
I do have to have the front of the deck slightly higher than the rear to keep from gouging the ground with the front runners .
UNUSED AGT SDA-140T LOADER (A51243)
UNUSED AGT...
Quick Attach EZ Axe Skid Steer Tree Shear (A52128)
Quick Attach EZ...
2018 WOOD MAXX TM 86H WOOD CHIPPER (A51243)
2018 WOOD MAXX TM...
Crosley 10ft. Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
