L3400 Shop Manual
   / L3400 Shop Manual
1.55 vs. 1.57 - Is that enough to be a problem?
My point is that if one wants to "fit" used tires, the most accurate starting point is the front to rear gear ratio. If the tires are close to the OTM specs, then you can play with the variables (tire wear, air pressure, etc...) to get the proper rolling circumference allowing the fronts to turn "positive" by a few percent.
The L3130 lists a couple options for the front tires and I'm not certain that he had the proper ones.
   / L3400 Shop Manual #12
Ok, Thanks... :thumbsup: Main reason I was interested in this thread was that I would like to swap or at least get a set of R1 - Ags. I like the R4-Industry for most things but they are too wide for row crops that I would like to get into.
   / L3400 Shop Manual #13
I'm looking high and low to find the front to rear gear ratio for my L3400 HST. If anyone has the manual indicating this, I would appreciate if they could post it. Thanks. C.
give Messicks a call- they usually can help
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2025 LandHonor PHA-16-2C Hydraulic 3 Point Hitch Adapter Skid Steer Attachment (A49462)
2025 LandHonor...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
