L3400 temperature gauge
   / L3400 temperature gauge #1
Chilly807
Elite Member
Nova Scotia
Kubota L3400DT
Those of you that have a 3400, where does your engine temperature gauge normally read after the engine is warmed up? Mine has a small tick mark just above the cold end of the scale, and the needle climbs to barely past that mark. Is this normal?
Chilly
   / L3400 temperature gauge #2
Yup, that's what mine does, until the screen in front of the radiator starts clogging up.
   / L3400 temperature gauge #3
Mine too. And how about the fuel guage? 9 gallon tank, and when the guage reads almost "e" , I can usually fill the tank with a 5 gallon can. Talk about a "reserve"!
:rolleyes:
   / L3400 temperature gauge #4
My L2800 temp gauge reads the same. Just above that dot when warm. The fuel gauge is also as Adiredneck reports. David.............
Nice to know mine isn't the only one, I was starting to wonder if I had a stuck thermostat. I'm used to seeing temperature gauges read mid-scale under normal conditions.
That's my kind of fuel tank !! I occasionally try to squeeze a few more hours running out of a tank that thinks it's getting low. Sometimes it works, sometimes you end up walking out to get fuel...
Chilly
   / L3400 temperature gauge #6
Ditto with L2800... and been there with the radiator screen clogging up, the needle will peg and steam will blow...
Not sure why they even have a 9 gallon tank if you have to guess after 5 gallons.
I've bled more than a few fuel systems after they've been run dry, a pessimistic fuel gauge is a godsend. The sooner we think it's empty, the sooner we refill it, and we're pleasantly surprised at the "great fuel economy" we're getting too !
Chilly
   / L3400 temperature gauge #8
Same temp reading on my L3400. I usually fill the fuel tank at about 1/4.
   / L3400 temperature gauge #9
How many gallons do you fill when it reads 1/4???
   / L3400 temperature gauge #10
Sounds exactly like mine on the temp gauge. When the fuel reads at 1/2, it takes a tad less than 5 gallons.
2011 Jeep Cherokee Laredo SUV (A50324)
2011 Jeep Cherokee...
1994 Chevy  2500 Dually Pick Up Truck (A50515)
1994 Chevy 2500...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
