L3400 Temperature indicator stays on C
   / L3400 Temperature indicator stays on C #1
Volnavy
Knoxville, Tennessee
L 3400 HST
I have a new L3400 HST (12 hours), even with several continuous hours of hard work digging and moving dirt in 60 degree weather, the temperature indicator never moves off of C. Is this normal? I haven't tried to trouble shoot it yet. Just thought I'd ask before I feel like looking into it.
   / L3400 Temperature indicator stays on C #2
Even on the hottest of days under heavy working conditions my B2710's temp guage rarely reads much more than 1/4" above "C". That is normal.
However, if I don't keep the radiator screen clean of brush and leaves it will go up.
   / L3400 Temperature indicator stays on C #3
Relax. In the summer heat (90 degrees or more in South Carolina), you may get 1/4 of the way to H on your temperature gauge, after working the tractor hard for a few hours. However, per the prior post, if your radiator screen gets clogged, the tractor WILL get hot, fast. When I'm brush cutting tall grass and weeds, I pull the screen and hose it clean after clearing my property - which only takes 3-4 hours. My first notice of a clogged screen is a slow creep upward in the temperature.
Thanks guys, I'll leave it alone then!
   / L3400 Temperature indicator stays on C #5
I Thought the same think when I first got my L4300. Put a bush hog behind it about July and it will get abit warmer /forums/images/graemlins/wink.gif
2021 Dodge Durango GT AWD SUV (A55758)
2021 Dodge Durango...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A55852)
2016 Autocar...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A55851)
2024 Wanco...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
