L3400DT grind when shifting?
   / L3400DT grind when shifting? #21
I wouldn't think you need to rev the motor. After pushing the clutch in everything in the tranny starts coasting to a stop. Once this happens there should be no grinding unless the clutch is not fully disengaging.
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
CATERPILLAR 22" PIN ON BUCKET (A52707)
CATERPILLAR 22"...
TIRE INFLATION CAGE (A55745)
TIRE INFLATION...
2023 Kubota SVL97-2 Compact Track Loader (A55314)
2023 Kubota...
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
