L3700 PTO Issue
   / L3700 PTO Issue
I dropped the mower yesterday afternoon for a grader blade to do a road repair. Afterwards, armed with a new can of PB Blaster, I had my neighbor repeatedly shift into and out of PTO, with the engine running while I hosed the arm and shaft at the case. After about ten cycles I got out from under and observed the PTO shaft while Don continued his shifts. It shifted in and out properly each and every time.
Conclusions: There are none.
1. The oil I had previously fed the cable finally took effect.
2. The PB Blaster on the arm/shaft worked immediately.
3. Not having the mower attached with its spin down rotation somehow made the problem go away and will return once the mower is re-attached.
I won't have the mower back on for another few days so I'll see about #3 at that time. If I don't post here assume the problem has been eliminated and it was simply a need to lube cable, arm and shaft. Of the three, I still believe that the cable was the most likely culprit and some patience is required after injecting oil, to see the benefit.
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2018 John Deere 35G Mini Excavator (A49461)
2018 John Deere...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2020 KUBOTA RTV...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
