L3830 Starting/Running Issue
   / L3830 Starting/Running Issue #1
clvickers
Nassau County Fla
Kubota L3830
I've had some issues in the past with my L3830 where I would get up on her and try to start her. When I turned the Key the engine would turn over but wouldn't stay running <I was hearing a click when I turn the key and another click when it shut down as soon as I let go of the key>. The throttle was pulled all the way back slow when this would happen. If I increased the throttle, then hit the key, the engine start up and run.
Jump forward to tonight. Started tractor and picked up a bale of hay and started backing out of the shed. Heard a click and tractor shut down. Restarted fine, moving again, and Click again... Shut down. It did it one more time before I got it back into the shed.
anyone else see this before???
I'm wondering if this is the OPC Relay switch that "awhite" was having back in 09.. :confused:
   / L3830 Starting/Running Issue #2
To make a difference in the throttle position as to if it would run or not I think the fuel shut off is not activating properly. I'd check the wiring and see if anything is loose first and clean the connections if needed.
1999 Vermeer SC505 Walk-Behind Tracked Stump Grinder (A55851)
1999 Vermeer SC505...
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2001 CATERPILLAR CP-563D PADFOOT ROLLER (A52707)
2001 CATERPILLAR...
TANK MANIFOLD (A58214)
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
