L4310 Glow Plugs Light Staying On
   / L4310 Glow Plugs Light Staying On #1
RichNJKubota
Hunterdon County, NJ
Kubota L4310HST
The Glow plug light on the dash stays on after the engine is started. Have not checked if the glow plugs are actually getting voltage but suspect that they are. I've been just turning the key on and off until the light stays off and then start. But it's getting worse and more frequent. I suspect there is a control box/relay somewhere. Where is it? Any suggestions?
Thanks,
Rich
   / L4310 Glow Plugs Light Staying On #2
if this is a new tractor have it checked by dealer. are u sure the plugs are activated? or is the light just staying on?
   / L4310 Glow Plugs Light Staying On #3
Rich, my B21 will do that on occasion. It was more an issue with the key switch not springing back to the neutral or on position. A little squirt of WD40 took care of the problem. Might not be your problem but worth a try.
MarkV
   / L4310 Glow Plugs Light Staying On #4
I'm not sure if this is still the case; however, in older Kubota's, the light would stay on if you had a bad glow plug.
40' High Cube Multi-Door Container (A57149)
40' High Cube...
2014 GENIE Z-60/34 BOOM LIFT (A52709)
2014 GENIE Z-60/34...
2016 Ford F-350XL (A57148)
2016 Ford F-350XL...
2017 Ford F-250 Classic II Service Truck (A56858)
2017 Ford F-250...
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
SD Lanch SDLD25 Rubber Track Dumper (A57149)
SD Lanch SDLD25...
