L4400 and 3 bottom plows
   / L4400 and 3 bottom plows #11
I have plowed the rock, clay stuff that passes as soil with my Massey 1440 using a 3-14 bottom for several years. My tires don't have liquid ballast but I do have 400 lbs of cast on the wheels.
   / L4400 and 3 bottom plows #12
Maybe I'm late to this parade but I want to play too. :)
The old wisdom said one horsepower per inch of bottom.
Thats a broad statement and doesn't consider soil types but just FYI, I pulled a 14" two bottom with a L3240 HST which has 25 pto horsepower.
PTO power relates roughly to Drawbar horsepower so...
Two 14" bottoms would require 28 horsepower. By those figures, I was slightly underpowered but my soil is sandy loam and I pulled plow reasonably well at a speed around 3.2 to 3.8 mph.
I now pull the same plow with a L5740 with 50 pto HP and I can already see (tractor is not broken in yet so I haven't hammered on it) that I can run away with the two bottoms. I've pulled it 5.5 mph and still have some left. but that's a bit too fast.
Your tractor has 36 or 37.5 PTO power (depending on whether it's an HST or Gear) and a 3 bottom 14" plow by the old rule would require you to have 42 HP. Since your soil is sandy, I say try a 3 and if you can't pull it the way you want, drop a bottom as everyone else has suggesed. You ain't gonna hurt the tractor.
Just my $.03 (adjusted for inflation)
edit, are you two wheel drive or 4. I left that out of the equation. Two wheel drive in that tractor and a three bottom might give you a bit of a problem. Another thing, your tractor weighs about the same as my L3240. I could not pull the two bottom at any reasonable depth in two wheel drive. I just spun. Good luck
   / L4400 and 3 bottom plows #13
i have no issues pulling a dearborn double 14" with my L4400, through tough, clay-ish, rocky virgin ground, uphill. i would like to think i could pull a triple if i had to in more forgiving ground
23'x22' Double Garage Metal Shed (A53316)
23'x22' Double...
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
2014 Jeep Patriot SUV (A55758)
2014 Jeep Patriot...
5' S/A CART (A52706)
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A56129)
2008 AAR MOBILITY...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
