L4400 busted rear axle housing
   / L4400 busted rear axle housing
Thanks fella's for the reply's.It is going back to the dealer tommorow,glad to here this is not a problem with kubota's.I will try to get a picture before it goes back.If you are standing behind the tractor looking at the back right tire,follow the houseing from the tire back towards center of the tractor.IT busted at the first flange on bottom side,almost entire bottom side.You can see a gear and I dug a couple of loose bearings out.Both sides of flange is busted,and this is also where the FEL mount brace connects too. I will see if I can round up a camera for some pictures,thanks agian for reply's.
   / L4400 busted rear axle housing #13
Doses your tractor have a <font color="orange"> Kubota </font> FEL?
   / L4400 busted rear axle housing #14
   / L4400 busted rear axle housing #17
Another poster had something similar happen to his L3400. Check it out here.
Once might be a fluke, twice....Not good. Keep us updated.
   / L4400 busted rear axle housing #18
   / L4400 busted rear axle housing #19
How does a rear axle housing failure seem similar to a top link bracket failure from a 3PH backhoe? /forums/images/graemlins/confused.gif
   / L4400 busted rear axle housing #20
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A53473)
UNVERFERTH 330 8...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
UNUSED AGT 46" EXCAVATOR HYD BRUSH FLAIL MOWER (A51248)
UNUSED AGT 46"...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
