L4400, connecting to the PTO
   / L4400, connecting to the PTO #1
challengertn
Southern middle Tennessee
MF 135 soon to be Kubota
Late this evening I tried, for the first time, to hook an implement to the PTO. I found out quickly that you cannot turn the PTO shaft to line it up with the splines of the shaft for the implement. What am I doing wrong? Is there a way to release the shaft so it can be turned by hand? Thanks, I can call the dealer tomorrow but sometimes it's hard to talk to someone who knows over the phone.
   / L4400, connecting to the PTO #2
Try turning the shaft on the implement. /forums/images/graemlins/grin.gif
It takes a little determination sometimes, but the shaft will eventually turn. This is what I do when connecting to a 6' tiller and a 6' bush hog.
Before I realized that the implement shaft could be turned, I would engage the pto on the tractor for a second or two, then try to connect the implement shaft /forums/images/graemlins/confused.gif.
I would - sooner or later - get the splines lined up. I don't recommend this way /forums/images/graemlins/tongue.gif.
If your connecting to a tiller, the tines have to be off the ground to turn the shaft.
Hope this helps.
   / L4400, connecting to the PTO #3
Yep, turn the shaft on the implement. If you even think about engaging the PTO----STOP and think again. Some of the regulars on TBN advise to turn the engine OFF and pocket the key before hooking/unhooking an implement to the PTO. Imagine how much more trouble you will have connecting to the PTO with only one arm/hand...............
I did a little experimenting today when I hooked up the tiller. I had been doing it like you said but after I hook up the tiller and raise it up it is hard to get into the PTO shaft. Today I shut off the tractor after I connected the 3pt and took both shifters out of gear and raised the seat and I was able to turn it by hand for a few inches each way. I don't know what part of this combination enabled me to be able to turn it but it worked. I had read where the Kubotas were designed to turn a few inches and that the seat was part of the safety switch. So I just tried everything. Thanks for the replies.
   / L4400, connecting to the PTO #5
I hooked up the 5' bush--hog to my 4400 this weekend, I experience no PTO problems, although I only had to turn it a few degrees to get alignment.
   / L4400, connecting to the PTO #6
I have to raise the tiller to spin my PTO also. I have a long heavy screw driver that I keep in my Tractor tool box just so i can ut it in the knuckle of the PTO shaft to spin it - I makes it a lot easier. If you do that make sure the tractor is OFF, you have the key, & you do not force it so you hurt the shaft/impement.
2009 Ford F-250 Ext. Cab Enclosed Service Truck (A53422)
2009 Ford F-250...
UNUSED SWICT 60" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 60"...
2017 VOLVO VNL TANDEM AXLE SLEEPER (A54313)
2017 VOLVO VNL...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
2017 KENWORTH T680 SLEEPER TRUCK (A54313)
2017 KENWORTH T680...
