L45 or Grand L40 Series
   / L45 or Grand L40 Series #11
Tailrotor,
What is the height of the L45 cab (assume lowered backhoe boom). I was wondering what height garage door you need to get it to fit. Do you trailer it and what is your combo?
Thanks
ChemE
   / L45 or Grand L40 Series #12
Tailrotor,
Thanks
ChemE
I have 10 foot low profile doors on my garage. And I lower the boom when I go into the garage but I don't have to I have about 2 inches of clearance to work with it is close. The height of the cab is just about 94 inches high, And I am working on a trailer right now will be getting one in the spring. Found a 2000lbs trailer with 10,000lb GVW 18 foot for $3100.00 made by Hudson brothers. I have to stay under 10,000 GVW AND 26 K Combo.
   / L45 or Grand L40 Series #13
94 inches is close for my 8 ft. door height! Thanks for the info.
   / L45 or Grand L40 Series #14
This is what "close" will do for you.:) Top and side.
   / L45 or Grand L40 Series #16
I owned an L39. Great tractor. The added HP and the Hydro trans on the L45 take it a step further. Otherwise, basically the same tractors. The TLB series tractors are Kubota's construction grade tractor. The Grand L series is more of an AG tractor. Look at the hydraulic pump flow between the two. The L45 is built more HD due to it's intended use for construction.
2018 Autocar ACX Xpeditor Garbage Truck (A55852)
2018 Autocar ACX...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
JCB 409T4 WHEEL LOADER (A52707)
JCB 409T4 WHEEL...
