L45TLB Info
   / L45TLB Info #1
DraftHorse
Surprise, AZ
Kubota GL3130
Anybody hear what the specs on the new L45TLB will be? Curious on the lift capabilities of the loader.
   / L45TLB Info
FYI
Did find some info on it, so I thought I'd pass it on. It seems that it is based on the L39 frame. What I did find out is:
4 Cylinder 45HP
Weight with loader and backhoe is approx 7200lbs
Loader lift capacity to max height height at pivot is 2848 Lbs
Loader breakout force at pivot is 4530 Lbs
Max lift height at pivot pin 113.9"
BackHoe is 121.0" max dig depth
The backhoe will be availible with a Hyd thumb.
   / L45TLB Info #3
I spoke with my dealer yesterday and he saw and drove it at the dealers show. He said it's basically an L39 with a four cylinder engine and HST Plus. He said the tires looked smaller, but after looking at both spec sheets he conceded the tires on both are the same size.
He said the only thing, as a rental yard owner, he did not like was that Kubota put a hand parking brake on it like the M59. He has problems with customers leaving parking brakes on and burning up the brakes.
Now I'm a bit disapointed, as I had hoped Kubota was going to put a turbo on the L39's 3 cylinder. I like the low end grunt a turbo makes and how it cleans up the exhaust smoke. I also like the way the L39's 3 cylinder sounds. But I guess we can't have everything. At least Kubota did not drop the model.
   / L45TLB Info #4
A L39 frame is too small for what they are trying to replace.....the L48.....wish they did something different. L39 frame & tires are too small for this niche machine. Put a L39 next to L48 and see what you think.
   / L45TLB Info #6
The M59 may have replaced the L48 size wise, but how about the L45 vs. L48 cost? If it is even close, I would still want the L48 any day. Bigger, better machine dollar for $. Up here a M59 without thumb is $52K, L48s where $40K-.
   / L45TLB Info #7
A few more specs of the L39TLB and L45TLB
L39 ---------------------- L45
111.4 cu in engine ------- 134.1 cu in
10.6 gal tank ------------ -11.9 gal tank
3 cyl -------------------- 4 cyl
same size tires
wheel base 68.9 ---------- 72.5
tire tread width 51.8 -------56.1
weight 6987 lbs ---------- 7173 lbs
Max speed 14.3 mph ------ 14.9 mph
pump capacity 23.4 gpm --- 25.0 gpm
3pt hitch std --------------- optional
Glide shift ------------- Hydro HST-PLUS with H-DS
--------------------------- Hydro Dual Speed within each range
----------------------------- 3 range Hydro
----------------------------- Load sensing ability
--------------------------- HST Response Control
---------------------------- -Auto Throttle Advance
-------------------------------- Feather step Control pedal
No Crawl Mode ------------------- Crawl Mode
Loader Compare
TL1000 --------------------------------------TL1000A
LIFT max AT pivot PIN 2767LBS ----------------2848LBS
Breakout force at pivot pin 3560LBS -----------4530LBS
BH Weight 960 LBS ----------------------------1040 LBS
Max lift height pivot pin 114.2 -------------------113.9
Clearance in dump 90.0 --------------------------90.0
bucket rollback 45 ------------------------------48 deg
carrying height 45.3 -----------------------------55.2
Auto level ------------------------------ --Auto level with on/off switch
BackHoe
BT1000 ------------------------------- BT1000A
Dig Force Bucket cyl 5825lbs - - ------- - 5825lbs
dig force dipper cyl 3779lbs -- ----- 3779lbs
transport height 103.6 --------------- 106.3
Max Dig Depth 121.0----------------- 121.0
Specs could change before product hits the dealerships
Took the Awesome L39 and Made an upgraded L45
Emerich Sales & Service inc
all specs are subject to change
   / L45TLB Info #8
Those prices seem way high. Barlow Equipment is a WHOLE lot cheaper for the same product. At the prices you quote a guy could buy from Barlow and ship it home cheaper??? What's up with your local dealer? Monopoly thought pattern maybe?
   / L45TLB Info #9
yankee way of thinking, don't sell ten machines at a thousand over costs,, rather sell one machine at ten grand over costs,, See all the time and paperwork saved on one sale verses ten?
   / L45TLB Info #10
I am not sure on pricing, but when I buy machines I check both dealerships here in NH and they are always within a close margin. How much are people out there paying for new L48s and M59s? I was told the prices went up about $1,800+/- due to fuel, steel, and rubber alone since March. Even used L48s with low hours are way past $30K+.
UNUSED FUTURE FT13J EXCAVATOR (A51247)
UNUSED FUTURE...
UNUSED CFG INDUSTRIAL MH12RX EXCAVATOR (A51247)
UNUSED CFG...
Engel 20' Boat (A50121)
Engel 20' Boat...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2020 John Deere 8R 410 MFWD Tractor (A53342)
2020 John Deere 8R...
