L6060 Leaking oil from weep hole in bell housing!
   / L6060 Leaking oil from weep hole in bell housing!
Yes, the 3430 was an HST model. I kept expecting the leak to get worse but it never did. I made sure the dealer knew about the problem just in case. He said pretty much what you did. Splitting the tractor for such a minor issue could cause more trouble than it fixes.
A coworker of mine bought a L3830 about the same time I did and he had the exact same problem. He still has the tractor and it still drips about the same as when he bought it.
Still, I agree with some other posters. It's a shame Kubota hasn't fixed the problem.
BTW, I just bought a L6060 a few weeks ago. I've got 48 hrs on it and so far (knock wood) no leak.
Keep me posted on your new L6060 and if it ever starts to leak.......sending good vibes your way.
Wonder if the hrs when leak starts is related to how much time is spent in 4wd not sure if the front drive shaft always turns or not? Over first 50hrs approx:
60% in 2wd
40% in 4wd
My hydraulic fluid is right at the top of the full line can't imagine there is an overflow within bell housing causing leak.......I wish?
I agree with most and if the leak doesn't get worse I'm not interested in having it split to fix any time soon. I'll wait until year 4 or 5 of warranty maybe I'll have other issues to fix....hope not.
   / L6060 Leaking oil from weep hole in bell housing! #22
60% in 2wd
40% in 4wd
The front shaft will ALWAYS turn as the rear axle giver or take a couple percent & the differences in axle ratios. There are no front hubs you can disengage like on a 4x4 truck so the front running gear will spin if the wheels do, regardless of the transfer case is in 2wd or 4wd.
Definitely a difference in power transmitted, maybe vibration, but not in amount of spinning.
   / L6060 Leaking oil from weep hole in bell housing! #23
The shop foreman told me the seal he put back in was better than the one that failed.
Not surprising. Kubota knows they have a problem, and they're trying to band aid it by putting a layer of felt around the seal, at least that's what the one I used looked like. If it starts leaking again, the felt will soak up the oil for a while, then you'll be back to that steady drip, drip, drip. I'm a few hundred hours past my repair, and so far, so good.
Oh, my bad seal was on the propeller shaft. Yours?
   / L6060 Leaking oil from weep hole in bell housing! #24
Yep, main seal, but my shop foreman replaced a couple others since it was apart.
He initially sent a field tech out to evaluate to see if it could be fixed on site and said running it with a leak was no big deal. This is my fifth Kubota and first with any problems. My L5030HSTC had over 1500 hours with no issues.
   / L6060 Leaking oil from weep hole in bell housing! #25
Interesting thread.
I have a 2015 L6060, bought in Jan 2016, just a few months before Kubota increased the power train warranty to 5 years. Annoying, because I was in no hurry to buy the tractor but bought it in the off season because I had more time. Grrrrrrrrrrrr!!
I do not put many hours on my tractors so my warranties always expire on elapsed time rather than hours.
I had a serious issue with a 2007 MF, bought new with 24 Mo/2000 Hr warranty, at 240 hours but out of warranty on elapsed time. The issue was an obvious manufacturing defect (In a previous life, I did warranty analysis for GM for years after other years as a design engineer.) but both MF and their dealer told me to shove it.
My L6060 shows no signs of leaking but this is a serious concern for me. My tractor has about 80 hours at this time but the warranty will expire on elapsed time in January.
Sometimes manufactures (not MF/AGCO) will protect purchasers after expiration of warranties, especially regarding known issues. GM has been quite good in this regard.
Anyone, have any experience regarding Kubota's policy in this regard?
SDT
   / L6060 Leaking oil from weep hole in bell housing! #26
My tractor had been abused by the PO, and when I got it the FEL mounts had been broken and weld repaired. I'm a pretty good weldor and machinist and figured if they broke again I could fix them. In another 20 hours of operation the welds were cracking, so I ground out the cracks, preheated the assembly, then MIG welded them back together. Made sure they cooled slowly to keep the heat affected zone intact. Another 20 hours later they were cracking again. That's when I went on TBN and found other people with the same problem. Talked to the dealer, showed him the TBN posts and pictures of the broken mounts, and asked if there was anything Kubota would do about it. After a lot of back and forth it came down to me paying for shipping for a new pair of mounts to the tune of about six hundred bux. But that was after they accused me of abusing the tractor and said the same about the other TBN posts. When I got the new mounts it was obvious that Kubota had really beefed up the parts that were cracking, even though the dealer assured me that no changes had been made. I asked for my shipping costs back because it was obviously a manufacturing defect that Kubota was aware of, but got nowhere. There's a link in my sig line if you want to know more about the LA724 mounts...
   / L6060 Leaking oil from weep hole in bell housing! #27
Thanks for the feedback.
$600 for shipping sounds excessive but at least they replaced the mounts.
I'm a VERY good customer at my local CNH/Kubota dealer and they try to keep me happy but I'm sure that they will not eat a split/seal repair if Kubota does not cover it.
I have no issues so far. Hopefully, I will not, but I'm not a lucky guy.
SDT
   / L6060 Leaking oil from weep hole in bell housing! #28
Bought an L6060 last December and now has 53hrs. Started noticing the odd oil spot on my garage floor at 30ish hours yup it's leaking transmission fluid from the weep hole because a $20 seal within bell housing!
Called my dealer who eluded to what needs to be done to repair yes split the tractor like I figured. Ok so yes I have warranty so no cost to me except my closest dealer where I bought is 220km one way. Kubota doesn't pay floating service as part of the warranty process which I was told when I purchased. I'm mostly ticked because my brand new tractor needs to be split with parts scattered all over the place....never the same at least that's how I feel just how I am.
I sold my 2012 Kioti that never went back to the dealer once. Now I have this leaking Kubota that needs to be split in half all because a known issue that should be addressed by Kubota Engineers don't tell me they aren't fully aware of the problem.
My relationship with Kubota quality is getting off to a bad start.
Hoping to hear from L60 or any other model owners who've had the same problem and how the service went.
A guy ranting against Kubota on my Initial impressions of a Kubota L6060 explained that both of his L5740s Kubota had the same oil leak, except since his was used for commercial snow removal, Kubota didn't honor the warranty. Check out Martin Guenette's comments buried on this page: Kubota L66 first impression - YouTube
   / L6060 Leaking oil from weep hole in bell housing! #29
My L3240 had the same problem. It leaked a little bit for years. One day it started coming out in a stream, but only when hot. I could get 30 minutes out of it before it started leaking. I split the tractor and the seal was intact, but a new seal fixed the problem. It never leaked again for the remainder of the 150 hours I owned the tractor.
   / L6060 Leaking oil from weep hole in bell housing! #30
I bought my L5240 used with 798 hours on consignment from a dealer. It was split and this seal replaced at the dealer in the winter of 2014. It sat until I bought it in August of 2015. It was leaking a week after I brought it home and I had no warranty.
I asked the dealer to send me a parts list from the seal replacement. When I had the tractor split myself in 2016, the part number had been replaced with a newer seal, so there was a redesign somewhere between 2014 & 2016.
It will be interesting to see if this new seal does the trick and how long it lasts.
2017 JLG 1932R 19ft Electric Scissor Lift (A50322)
2017 JLG 1932R...
2010 John Deere 6100D (A50120)
2010 John Deere...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
Ford F-450 Utility Truck (A52748)
Ford F-450 Utility...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
