tanksrcool
LA403 bucket will periodically lose pressure and "bounce" when under pressure
My Kubota B7800HST with LA403 loader works fine 99% of the time but will periodically "bounce" (suddenly lose pressure then quickly recover) when I'm using down pressure with the bucket when the front of the tractor comes off the ground... other times, 99% of the time the kubota works fine and will lift the front of the tractor smoothly several feet off the ground with no problem. When it happens it seems to lose all pressure, will come down suddenly then instantly start lifting again and will "bounce" a few times then will start working fine.
Also let me add, I've been hauling dirt and I don't have any problems lifting and hauling, I don't lose any pressure and everything seems to work fine with hauling/dumping.... it's only when I use the bucket to lift the front of the tractor off the ground it seems.
I'm thinking the problem is with the relief valve (YW233-95100) in the valve control assembly (YW244-00100) just below the control lever? Any thoughts if this might be the problem, or something else?
Thanks,
Brian
Thanks,
Brian
