Lack of drive power
   / Lack of drive power #1
richla
Husqvarna YTH150
Hi Gang:
Point me in a direction, here, please:
I recently changed the drive belt on my Husky YTH150 lawn tractor. I had hardly any power on the slopes that are on my yard.
I replaced the drive belt and seem to be about right where I was before, with a serious lack of drive power on hills, I seem fine on the flats.
Keep in mind the tractor is in good shape, I maintain it, engine is running well, etc. I'm stumped.
My book suggests changing the belt, or bleeding air out of the transmission.
(I have not bled the transmission)
Any other thoughts?
   / Lack of drive power #2
Maybe brake brake grabbing.
Does the transmission have filter,if so last time change.
Does transmission have rod w/two settings..dis engage to push tractor by hand/engage tractor moves on its own.
   / Lack of drive power #3
i have the same problem i have the 48 inch model YTH2348, this mower is only about 1 1/2 years old and has 111 hours, its been a lot of problems and headaches.. but this is the worse of the problems.
it wont go forward, will go reverse to a point then will go forward for a little bit, but refuses to go up any kind of incline. the transaxle fan seems to be working, there are no fluid leaks that i can find, and the rod is engaged for the tractor to move its self... any help would be great
my book also says bleed the transaxle but i cant find where it say how to do this...?
   / Lack of drive power #4
There was a problem a year or two ago with some of the mowers, I believe the yth2348 was one of them. The rod on the rocker pedal was not the correct lenght, limiting forward travel speed. I believe Husqvarna had a recall on that item since it was not adjustable.
I'm going off of memory from when I was mower shopping, but believe that is your problem.
   / Lack of drive power #5
I have checked the linkage rods, they look ok, the problem im having is that it worked fine for about 1.5 years and now all of a sudden its not moving. is it that the linkage became "unadjusted" or were they not right from the beginning?
i would sure appreciate any help in what to be looking for to correct this problem.
does any one know any thing about purging the transaxle?
   / Lack of drive power #6
As I understand the problem was that the welded and un-adjustable rod was too short and did not properly engage the transmission. The correction was to replace the rod that went from the rocker pedal to the transmission.
I ended up going with the yth20K46 for this reason and also wanted a much simpler mower without the electronics involved with the other mowers.
   / Lack of drive power #7
ill look at the rocker linkage and see if extending the rod will do anything, any one else got any ideas on this problem????
   / Lack of drive power #8
The hydro transmission could be a problem. Get the model number of it and manufacturer. You can call them on it too.
Steve
   / Lack of drive power #9
It sounds like your hydrostatic transmission has failed as mine and many others have.
CONTACT INFO (A53084)
20717 (A55853)
20717 (A55853)
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2015 FREIGHTLINER CASCADIA DAYCAB (A55745)
2015 FREIGHTLINER...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A56129)
2018 FREIGHTLINER...
