Land Clearing
   / Land Clearing #1
JoeR
Platinum Member
Central Florida
Kubota L5030HSTC
I cleared 3 acres of land and burned most of the debris. I still have some small roots, twigs, and small branches 1-3" that did not burn. They are all tangled together with ash and sand, and I can't seem to shake it out. What should I do with this leftover debris? Disc it in? Get a tiller for the tractor? I was thinking a tiller might do a good job mulching it into the soil.
Any ideas?
Thanks,
Joe
   / Land Clearing #2
I wouldn't want to run my tiller through anything larger than 1". You would spend most of your time trying to pull them out of the tines where they had jammed the slip clutch.............:( /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
Disking maybe..........
Best wishes,
Ron
   / Land Clearing #3
dig a hole and bury it.... that is the fastest way.... and easiest....
   / Land Clearing #4
Junkman's right. Since you have the BH, just bury it. You would be fine doing that with the small items that you mentioned. However, I would not bury bigger items like stumps. They will eventually rot underground and create a sinkhole. It may take several years, but it will happen. Trust me...
RING 3 STARTS HERE @ 9:30 AM (A51244)
RING 3 STARTS HERE...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
