land plane / leveler
   / land plane / leveler
That would be great if you keep all your roads flat w/o any crown on them for drainage.
Actually they are all flat. Our main driveway to the house is about 500' and is concrete. These "roads" I am talking about maintaining are in the fields, turn rows , etc. They are just dirt and don't get driven on very often. Not that it rains much here but if it is too wet we don't have a need to travel on them. They get minor ruts from time to time from various things like atvs, etc but just making them flat again is fine. I know a proper road has a crown but these are not that important. I do like to keep me gravel parking area flat though.
   / land plane / leveler #12
Do these levelers draft harder than a box blade? I have pulled my 7' box blade plum full of dirt with a 45 horse tractor. I had a 10' box blade I used to pull full with a 4430. I think it was 125hp.
I can move about 4 CY of dirt with my LPGS if the dirt is moist. There are 2 blades cutting 1" of earth, it can pile up real fast. Yes it "can" be much harder to pull than a box blade. But all of this can be controlled. Maybe you should just get the 10 footer and be happy that you will be able to grade your roads with a single pass.
We TBNers go through this learning process all the time. All we can do is guess what your conditions are and give advise on what we think the situation might be. Until it is clear to us exactly what you have and are trying to do, a lot of our advice simply does not apply.
I am sorry that it took this long to get on the same page.:sorry: One last thing, you may not like the cost of a good 10' LPGS. My guess would be quite a way north of $4000. :eek:
Good luck ;)
   / land plane / leveler #13
I am currently working on a 14' wide model with 8 1/2' long skids which a 4430 should be able to pull. Just mentioned this because the lpgs is good for smoothing fields and pastures too, something you might consider useful,
Thanks again everyone for the advice. Looks like I will give a 10' unit a try depending on price. I can get a 10' box with gauge wheels for around $1500. I know it will work, but maybe not as good. If I can get into a LPGS for around 3k or less I will give it a shot otherwise it looks like I will take the cheaper solution.
   / land plane / leveler #15
   / land plane / leveler #16
... I definitely will look into the heavier units. The bulk of my dirt roads are about 10' wide so if I got a 10' unit I could cover the whole road in one pass.
You want to put a camber on the road so that you have 8 feet in the middle that doesn't keep puddles. For a short 300 yard one I put one corner of a blade down and made about 40 passes, with the down corner at the back and about 3 inches lower than the up end.
(Too light a blade)
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
RV TIRES & RIMS (A58374)
RV TIRES & RIMS...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
(2) EVENRUDE OUTBOARD MOTOR (A58374)
(2) EVENRUDE...
toro reel master (A56857)
toro reel master...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
