Land Plane - Yet another build
   / Land Plane - Yet another build
That sure is pretty!
What was done to prepare the field in advance?
How big a field & how long did it take?
How much below the skids are your blades set?
   / Land Plane - Yet another build #32
My drawing is a REAR view - everything added would sit ABOVE the existing ears to AVOID interference, but a 4" cyl. is a bit large for this :D - My advice is free, and worth at least TWICE that :rolleyes: ...Steve
   / Land Plane - Yet another build #33
I agree, I don't think it would be a problem for Brian to get you set up. As long as you have the hydraulics you need the top link would be an easy fix.
And if you didn't already know Brian = MtnViewRanch = FitRite. Good reputation on this board. I know I'm happy with my TnT gear from him.
He custom makes most or all the cylinders, or at least the mounting points on the ends.
   / Land Plane - Yet another build #34
I started this job in May removing old apple trees and stumps and about 6 borders or terraces. Then leveled the field with my box blade and laser. Have about 12 days in this project for clearing and leveling. The land plane was just to slick it up and only took an hour or so. My land plane is fixed with the blades flush with the skids and blades are set straight.
I leveled this with my 3ph Frontier (Gannon) box blade and a Topcon laser and receiver, manual control no wheels and lots of rubber necking. Once I collect on this job the proceeds will pay for the automatic machine control add ons, I am sooo ready. This field is only 4 acres but that is a lot to smooth out with a 3ph box blade.
   / Land Plane - Yet another build #35
It will real easy to add flat bar to the bottom of the skid as needed. I am keeping my eye out for something appropriate at a salvage price.
2020 MDB UT125KPLUS FLAIL MOWER (A51406)
2020 MDB...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
1996 INTERNATIONAL 4700 4X2 SEWAGE PUMP TRUCK (A54756)
1996 INTERNATIONAL...
2017 Ford F-150 Pickup Truck (A55788)
2017 Ford F-150...
UNUSED RAYTREE RMT48 HYD TRENCHER (A54757)
UNUSED RAYTREE...
2006 Toyota Tundra 4X4 Pickup Truck (A55788)
2006 Toyota Tundra...
