Land Plane
   / Land Plane #11
Thanks for the info and the LP will be used for filling in potholes/washboard on gravel roads/driveways. I’m thinking it will be 6’ wide and 5’ long(the sides). The final weight will be around 600 lbs. I have a 6-way rear blade coming with the tractor also.
Hopefully your rear blade is at a minimum of 700lbs. 800lbs would be even better. Do you have a 7' blade ordered?
Need to keep in mind that weight is typically your friend when it comes to grading.
   / Land Plane
Yes, It is a 7' rear blade. I want be doing any long roads, mostly just driveways and you don't see long driveways up here very much.
   / Land Plane
I think it is made by Titan. It was in a package deal so probably not the best but should work for now(hopefully).
   / Land Plane #15
Just three weeks ago I received my new 6 foot Everything Attachments 6 way blade.
What a fine piece of equipment it is.
Sitting side by side, it makes my 7' KK blade look like a home built.
   / Land Plane
It was going to be over $600 in just shipping for me to get a Everything Attachment 6-way blade that I wanted.
   / Land Plane #17
Being in Alaska, sort of how it is isn't it? I just hope that the lighter weight stuff works out for you.
That $600 may not be as bad a hit if you were to get a couple of attachments from them at the same time. Not that it matters now. But maybe something to consider later. ;)
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
2021 CATERPILLAR CB2.7 DBL DRUM ROLLER (A52705)
2021 CATERPILLAR...
UNUSED WOLVERINE PFF1-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
