Land Pride RFM
   / Land Pride RFM #1
Typhoon
Southern Illinois
LS MT357HC
Well, a couple days ago I mentioned that I was going to possibly try a 6 foot King Kutter finish mower to use behind my TC29D. Well, after some more investigation, I found a local dealer that carries Land Pride. Apparently, Land Pride carries 2 lines of finish mowers... a light duty and a heavy duty. Well anyways, all this dealer had in stock for me to look at was the heavy duty one. I must say I was VERY impressed with the way this thing was built, and the service manager at the shop was really talking it up. The unit sells for 1,800.00. I am really leaning towards this one. For those who know, how do you think this unit stacks up against the King Kutter? Thanks!
   / Land Pride RFM #2
I don't know the Land Pride line but I have looked at the KK at TSC and visually compared it to my Woods RD6000: there really isn't a comparrison. The woods is a tank, very heavy duty (650 lbs) and based on it's condition on it's 3rd season I expect it to last a lifetime with care. I also contibute it's shear mass to the excellent cut quality I get. Might just be a "Tim Taylor" 'ism but that's my impression.
Good luck
Kevin
   / Land Pride RFM #3
I have a 6 foot King Kutter finish mower. It does alright & the grass looks nice, but the quality is not the best. The metal can & will bend easily. The belts are not easy to change either. One of the belts broke already & I have only used it one season. Had to do over again, I would not be buying a King Kutter.
Chad
   / Land Pride RFM #4
I have used a Landpride 5 foot rear discharge finish mower RD 2560 for about 2 years. It leaves a very clean cut and has been trouble-free. They come with medium lift blades which suck up the grass really well for a well manicured look. I paid about $1,800 and am very pleased with it. Hookup is easy. I did get the optional front anti-scalp roller.
   / Land Pride RFM #5
I own a Landpride fdr 1660 rfm, this is the light weight unit. I will tell you that this light weight unit is also built like a tank. It weighs in at about 600# and all the metal is heavy steel, it cuts my three acres of lawn very well and leaves a manicured lawn.
Just my 2 cents.
   / Land Pride RFM #6
I've used a FDR 2584 (rear discharge) for the past two years. It was $2200 new. I've really abused it, using it to cut paths in pasture. The T-post I hit just stopped it cold, but the 8" rock that must have rolled down the hill and hid in the clover blew out one of the spindle hubs. My fault - replaced the hub for $65. Put new blades on (I feel safe doing that now since the first set found all the rocks) and the mower does a beautiful job. This mower is built to last.
No experience with King Kutter, but I love my LandPride.
   / Land Pride RFM #7
I picked up a Land Pride FDR 1660 Rear Discharge Finish Mower this spring.
So far so good.
We have very sandy soils so I go the heavy duty low lift blades. Even with the low lift blades it gives a nice cut. Not sure if this is the heavy or light duty unit, but the way it looks to be built I expect it will be the last one I have to buy.
I think I have found all the rocks, including one that I needed the FEL to lift. Hope to get by with a little sharpening and maybe straightening of the blades before the next mowing.
Good luck.
   / Land Pride RFM #8
I have a Landpride 1660 I use with my 7500, both bought last spring. The Landpride cuts and is built very well. I use it mostly on the 3 acres of "field" I have. Sometimes when I want a fast cut I use it on the 1 acre manicured St. Augustine grass around the house and it gives a beautiful cut. I paid $1595 for the Landpride.
   / Land Pride RFM #9
I have owned several Land Products over the years. Typically they come in series 15(16) , 25, and 35 with 15 being the lighter duty and 35 being the heavier duty.
Of the current mowers.
FDR16 Series 15-30 HP 48", 60", 72"
  FDR25 Series 15-45 HP 48", 60", 72", 84"
  FDR35 Series 25-60 HP 90"
I have always found the LandPride products to be of good quality.
Andy
   / Land Pride RFM #10
I have a Landpride 72" AT2572 side discharge. I just replaced it yesterday with a First Choice 84" rear discharge. There is no comparison: the First Choice is INCREDIBLY heavy duty - heavier deck, spindles, gearbox, wheels, covers, A-frame, and arm assembly. I don't know what the 72" version costs, but Ken Sweet at Sweet Tractor had the 84" for $1499 (+ $165 freight, but less $67 sales tax.) I have looked at the KK stuff and found it lacking compared to Landpride and First Choice, but at least it is cheap to buy. There is a higher-end KK line, but I have never looked at it.
Good luck!
Mark
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
New/Unused AGT MX-CRT23 Mini Skid Steer Loader (A51573)
New/Unused AGT...
New/Unused Quick Attach Post Driver (A51573)
New/Unused Quick...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
Hustler Raptor Limited Zero Turn Mower (A51573)
Hustler Raptor...
UNUSED MOWER KING 72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
