Flail Mower Land Pride vs. Caroni Flail
   / Land Pride vs. Caroni Flail #1
j845125
This site has convinced me of the purchase of a flail mower to replace a worn out finish mower and an almost dead rotary. I got quotes for Land Pride 72" for $4800 as opposed to $2000 for a Caroni. Is the Land Pride worth $2800 more? I will use it alot, but not beat it.
   / Land Pride vs. Caroni Flail #2
I own the Caroni TM1900 but have never seen the Landpride. The Caroni is what I would call a medium duty rough cut flail. The much more expensive flails like Alamo and other similar flails are heavy duty. I have no idea if the Landpride is heavy or medium duty. If I were purchasing a flail to drive along and mow the shoulder of a highway I'd go with heavy duty. For mowing of pastures, fields and medium duty bush hogging the Caroni has been fine.
I'm starting my fourth season and have so far just replaced about half a dozen flails and associated shackles for under $40. I haven't found a use that would have demanded a heavier duty flail but I don't run into cinderblocks routinely either. I have run the flail into eight inch chunks of firewood (stalled the tractor, jammed the wood into the flail and needed a crow bar to get it out), I've wrapped old angle iron around the flail (PITA to unwind) and I do routinely hit the tops of surface rocks (likely where I've lost the half dozen flails that needed replacement). My use of the Caroni in bush hogging is largely to beat back twenty year old brush and the limitation I face in how fast I can travel seems more related to horsepower than the flail itself. Bottom line is that my Caroni is working just fine after three full years of combined bush hogging of brush (about an acre a year) and field maintenance (20 acres). Other than replacing lost flails occasionally, I just grease it before each day of work and check the gearbox oil.
I'd say that if the Landpride is a heavy duty flail then it is probably fairly priced but if it is a medium duty model then I can't see how it could have any significant advantage over the less expensive Caroni. Again, I haven't actually seen the Landpride so am making that call based on the satisfactory performance of my Caroni in a medium duty application.
Edit: I almost forgot, I tore up my first set of belts last year so I have spent about another $50 for a new set. Total replacement parts over three years about $100.
   / Land Pride vs. Caroni Flail #3
I own the caroni as well and like island said they do work well. i too have had to replace a set of belts, and i also bent my rear roller but i don't think it was a flaw on caroni side but me hitting a stump or rock. I've been very happy with my caroni and would buy again.
I will also say that this is my first flail and the only one i've ever used so i have nothing to compare it to.
Good luck
   / Land Pride vs. Caroni Flail #4
We've used a LP RCR1860 on our fields and barways for a couple of years now. Easily take out 3-4" stumps. Never had it break or even trigger the slip-clutches. Blades are tough, took off the top of a good sized buried boulder with just a small nickel sized burr that was easy to dress back up. LP lists them as 'medium duty' but they are built like a tank and do a nice job keeping our tree farm managed.
   / Land Pride vs. Caroni Flail #5
From my experience... yes. It's worth it. Nothing wrong with the Caroni, but IMO, it's not nearly as well built. Depends on the operator in many cases.
One thing I would worry about is parts and service, but that's just me. Yes, there are Caroni dealers in the US. I think that Ken Sweet (who posts here alot) is one, but I don't think there are many. If you lived close to him, or another *good* dealer that carries Caroni, you might get along great. However, there are Land Pride dealers everywhere. Take that for what it's worth.
   / Land Pride vs. Caroni Flail #6
No question there are more Landpride dealers but do they stock flail parts? Flails are not the meat and potatoes of their business. If not then there is really no difference from Caroni as it just takes an 800 number phone call to get parts from AgriSupply who seem to be the main Caroni importer. They get stuff out immediately and it saves a trip to the parts dept at the dealership. Parts have really been no problem from AgriSupply.
What I would like to see is non OEM companies like Flailmaster start to support the Caroni. It's not the end of the world but buying clevis' and flails directly from Caroni through AgriSupply is probably about twice the cost of what typical similar stuff costs from Flailmaster. I suppose I could just order some from Flailmaster to find the correct match but given the need to balance weight and size it would be better if Flailmaster simply matched the Caroni parts and listed them as such in their catalog. I haven't checked but as Landpride is a big US company Flailmaster might carry their consumables already.
   / Land Pride vs. Caroni Flail #7
So AgriSupply sells enough of the same or similar models that they DO keep all the parts in stock? Especially for 10+ yr old models? I didn't know that.
   / Land Pride vs. Caroni Flail #8
As far as I know AgriSupply has imported only about four models of the Caroni flail as well as the Caroni tillers and finish mowers. They stock parts for all of those. I don't know about older Caroni models. It is useful to note however that Caroni is an Italian company that is roughly the equivalent of Landpride or Woods or Rhino. It is a well established player in the business, not some Chinese knock off manufacturer with a questionable future.
   / Land Pride vs. Caroni Flail #9
Oh for sure. You're right that Caroni is an established company. I wasn't meaning to imply that they weren't if it came off that way. As far as equivalent to those other companies... I'd have to disagree. Doesn't mean it's a bad product.
Just my 2 pennies
   / Land Pride vs. Caroni Flail #10
After much reading on this site, I just received shipment of TM1200 caroni flail 48". the staff at agrisupply was very helpful. i ordered it thru the headquarters. Supposedly got one right off the boat because the three on the store lots were weathered and rusted a little. hooked it up to the bx 24 for about a half an hour of cutting and was very impressed with the cut (I mean, shread). I noticed that the tractor used quite a bit more fuel than i'm used to. Plan to get back out there this weekend.
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
2022 KENWORTH W900 TRIAXLE (A55745)
2022 KENWORTH W900...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2012 Mazada 3 Sedan (A55853)
2012 Mazada 3...
2022 Weber MT CF2A Plate Compactor (A55851)
2022 Weber MT CF2A...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
