Land Surveyors ... Question ... Price
   / Land Surveyors ... Question ... Price
G'Earth's polygon area/acreage estimator doesn't match what the neighbor/seller thinks the area in question should be.
   / Land Surveyors ... Question ... Price #13
   / Land Surveyors ... Question ... Price #14
Back in 1973 we had 50.65 acres parcel (wooded) surveyed with 6 turning points (corners) staked and survey recorded. The cost was less than $400.
I think registered surveyors take advantage of people today and charge what the market will bare. I have seen 1//2 acre lots in the sub-burbs costing upwards of $1500 to be surveyed.
"The cost was less than $400" ...... In 1973
Yup.....
In 1977 I bought a brand new Ford F-250 4x4 for $5680.
Comparison now?
Your time comparison is 46 years.
I was 33 years old in '73, and I am am 79 now.
No comparison there either !!!
Yes, still does not justify the outrages prices surveyors are demanding today. Sure, modern technology has created more sophisticated surveying instruments, but the same work can be done today with the equipment that was used in 1973. Understandably wages have skyrocketed since then. However we are not talking about manufacturing automobiles and the cost machinery and materials that go into producing them.
Can you still do the same work you did in '73?
   / Land Surveyors ... Question ... Price #15
I sure could do the same work I did in '73, but federal law would not permit me to do so, because of my age.
Federal age requirements mandated my retirement at age 60; 19 years ago.
   / Land Surveyors ... Question ... Price #16
I had 160 acres of property in the Arkansas Ozarks surveyed before I sold it about 2 years ago. It was a square piece. Price $450. I had 8 acres surveyed outside New Orleans 15 years ago. It was a long piece only 100' wide. Price $2400. I think they charge by supply and demand.
   / Land Surveyors ... Question ... Price #17
I’m a real estate lawyer. I deal with surveyors everyday. If they charge you more than $900 you are taking it right up the old doodaa.
   / Land Surveyors ... Question ... Price #19
Neighbor has 40 acres. We're talking about cutting out 2-3 acres for me to buy, sort of a triangle or trapezoid shape. Lies along a county road and is overgrown, but less than 'wooded'. One side is defined by a fence to another neighbor, then the road frontage, so only one line needs to be defined. All rural, no utilities other than within the county road right of way.
Due to undergrowth, probably will have to be walked rather than laser sighted.
Seeking a rough guess on what you would charge if in your area.
Where are you located? In most U.S. states, you can’t break up land into less than a certain number of acres without going through a formal subdivision process with the county. For example, in Colorado, the two resulting parcels must be at least 35 acres, which means you need at least 70 to start. Otherwise, you need approval from the county for a subdivision plat and I t gets considerably more expensive and time consuming. No matter what you do, you should go through a title company to make sure you actually receive what you are buying.
   / Land Surveyors ... Question ... Price #20
That’s a rather ambiguous statement, considering that the time involved is directly related to the complexity of the job.
$900 is only 4 1/2 hours for a two man crew, and they can’t do a lot in that amount of time. They also have costs including professional liability, travel time, deed research, ...
LENNOX 4 TON AIR CONDITIONING UNIT (A58376)
LENNOX 4 TON AIR...
2019 INTERNATIONAL LT625 (A58214)
2019 INTERNATIONAL...
Club Car Carryall Electric Utility Cart (A55853)
Club Car Carryall...
UNUSED CFG INDUSTRIAL H12R EXCAVATOR (A58375)
UNUSED CFG...
LOT: (2) Gear & Pulley Puller Sets (A59076)
LOT: (2) Gear &...
9ft. EZ Loader S/A Boat Trailer (A56859)
9ft. EZ Loader S/A...
