Rotary Cutter LandPride 1542 question
   / LandPride 1542 question #1
George the Beagle
Southern Maine
BX 2370
I purchased a used 1542 which was stored outdoors. I'm thinking the slipclutch should be checked to make sure it's working, but I can't figure out how to remove the plastic shroud around the pto shaft to gain access to the clutch. This has to be easier than it looks...I must be missing something fairly dumb here. Help! Thanks!
   / LandPride 1542 question #2
Mine had a port that you can pop off and get to the bolts one at a time. Mark the clutckes so go can tell that they have slipped.Mark the heads first, loosen each two turns, spin the PTO several times and make sure the clutches have slipped then tighten up the bolts back the two turns.
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A49461)
2017 Mack GU713...
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
2005 KENWORTH T800 (A50854)
2005 KENWORTH T800...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
