Tiller LandPride tiller shaft snapped
   / LandPride tiller shaft snapped #11
How did a 1 hour old tiller get so much rust on the shaft?
That is not rust, it's dirt/clay.
On another note, I sent LandPride a message today explaining what happened and am going to send pics as well. If I had many hours on it I would be ok with warranty, but being only an hour old and would mean dropping off the tiller, waiting for repair then picking it up, I would hope they could just exchange it.
Factory defect I guess. I hope !
   / LandPride tiller shaft snapped #13
madhatter said:
I have a LandPride 1050 tiller that I just bought and MIGHT have one hour on it. Last night while tilling DIRT I noticed the shaft was not turning. Thinking I broke a shearbolt I discovered the main tine shaft was broke in the middle ! This is a pretty thick shaft too, I have no clue why it broke before the shear pin. Pretty pissed off to say the least. Seeing it only has an hour on and it is brand new, I am going to ask for a complete replacement instead of fixing it.... very strange. hope this is an isolated incident !!!! :mad:
Was it an RTA or RTR?
How many PTO HP tractor were you using?
This is out of their Operation Manual...
IMPORTANT: Turning or backing up with rotary
tines in the ground will damage the tiller.
You didn't turn with it in the ground or backup with it in the ground?
It is a RTA1050, my pto is around 18-19hp. And no, I never backed up with it while in the ground. Just a factory flaw I guess. It is being repaired under warranty, was hoping for a replacement tiller, but at least it is getting fixed. Hopefully that is the only thing that goes wrong with it, seems like a good tiller other than that.
   / LandPride tiller shaft snapped #15
Well, as long as it was fixed under warranty...:D
You'll be tilling in no time...:)
   / LandPride tiller shaft snapped #16
It looks like the shaft wasn't annealed after welding/ heat treat. Notice the grain structure in the fracture, that is not normal for a failure with torsional stresses. It shows that the metal was to hard for the application.
2016 BOMAG BW 177D5 SMOOTH DRUM ROLLER (A52707)
2016 BOMAG BW...
(4) GOODYEAR WRANGLER 275/55R20 TIRES (A54757)
(4) GOODYEAR...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2018 Ford Fusion Sedan (A53424)
2018 Ford Fusion...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A55973)
2012 Chevrolet...
