Landscape Rake Problem with BX22
   / Landscape Rake Problem with BX22 #11
Junkman,
Having the benefit of seeing Mrwurm's pic and your first pic, it seems like his solution would help the most. From your pic, the beam is level, as are the gage wheel arms--this is probably the optimum situation. Unfortunately, you are out of lift ability with the BX.
Using Mrwurm's approach, if your attach points were 6-8" lower, you could maintain this level situation to dig and have some lift heigth to raise the rake. His approach is also the easiest to undo--if you sold the rake or upgraded to a bigger tractor yourself--just torch the addition off.
The way I build stuff, I always factor in the "undo" feature whenever possible--I've used it more than once! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Landscape Rake Problem with BX22 #12
I'm not sure about the BX model tractors but the B7500 units have two sets of holes in the lower link arms. By using one of the sets the lower links will lift higher. There should also be two sets of holes for the pins on the top link on the tractor. One set of holes will allow you to lift higher than the other. I would try adjusting the top and lower links before I start cutting up that rake.
Just food for thought. Let us know how you get it to work.
Joe M.
2022 Allmand Bros Maxi-Lite II Towable Light Tower (A52377)
2022 Allmand Bros...
2007 DOOSAN G25 GENERATOR (A53843)
2007 DOOSAN G25...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2009 TROXELL COMPANY 130BBL VACUUM TRAILER (A53843)
2009 TROXELL...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
