Landscape rake width
/ Landscape rake width #1
KBinCT
South Eastern CT
Kubota L3901 Ford NAA
I have a Kubota L3901 and a 1954 Ford NAA and am looking to purchase a landscape rake. What width should I go with, 5, 6 or 7 foot? It'll probably be used more on the Kubota than the Ford, Thanks.
/ Landscape rake width #2
I have a 6' rake on the back of my 2320 (24HP) and it's perfect for just about everything I've used it for. Unlike a oxblood or rear bad, it's tough to "fill it up" beyond a tractor's capacity to use it. My ONLY contrarian thought is that a 4 or 5' one might work better in the woods that I'm trying to clean up right now, but from an open-area usability perspective, I could have gone with bigger and been fine. I probably use my rake as much or more than any of my other implements for general clean up, smoothing gravel, and even plowing snow in a pinch. It's a highly usable and very versatile implement.
/ Landscape rake width #3
Your tractor could handle a 7' rake without a problem.
Will
/ Landscape rake width #5
Rake set at 45 degrees should cover rear tires thread and little more.
Just a update on my landscape rake search. I ended up buying a 7' rake from Everything Attachments and received it yesterday. Here it is hanging on my Ford NAA. Thanks for the help.
/ Landscape rake width #8
Nice, are the forks new too?
/ Landscape rake width #10
/ Landscape rake width #12
I think you made a good choice with the 7' rake. I have a 5' Frontier for my mower and a 7' Lienbach for my tractor that is got some age on it. I will replace it with an 8' rake for open areas, wider is better for raking imo. Just as long as you can fit through the trees if needed.
CASE TR310B SKID STEER (A62129)
CASE TR310B SKID...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
John Deere 1025R (A62177)
John Deere 1025R...
Great Dane Van Trailer (A63118)
Great Dane Van...
