Large swing in oil pressure- How come?
   / Large swing in oil pressure- How come? #11
I too am seeing a low oil pressure when the engine is hot. I'm getting down to 15psi. The pressure drop is steady, but slow. It takes around 45 min to get that low. Cold pressure is OK, around 35psi. Right now I'm using 15w-40 oil and I'm thinking of stepping up to a 20w-50 to see if it doesn't break down from the heat as much.
   / Large swing in oil pressure- How come? #12
   / Large swing in oil pressure- How come? #13
</font><font color="blue" class="small">( What do you think a minimum safe hot oil pressure would be? 10 PSI at 2,000 RPM would make me nervous.
)</font>
I've heard a rule of thumb of 6psi per thousand.. but that was generic info.
What pressure does the sender open on your unit.. that is the magic number that would make me crack her open.. when it starts letting the oil light come on at idle ( I've seen oil senders that open at 6psi... )
In any case.. having experience with ntique tractors.. status quo is to increase oil viscosity till presure is low on 50w oil.. then rebuild..
Soundguy
   / Large swing in oil pressure- How come? #14
)</font>
Soundguy
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2023 JOHN DEERE 3033R LOT NUMBER 90 (A53084)
2023 JOHN DEERE...
JOHN DEERE HX14 LOT NUMBER 266 (A53084)
JOHN DEERE HX14...
2013 PETERBILT 367 DAYCAB (INOPERABLE) (A52472)
2013 PETERBILT 367...
2023 JOHN DEERE 8R340 LOT NUMBER 221 (A53084)
2023 JOHN DEERE...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
