Largest HST Tractor in Aus?
   / Largest HST Tractor in Aus?
It sounds to me like you may well end up with a couple of tractors.
I hope not - the budget is tight for one!
I should have a look at backhoes. Thanks for the suggestion.
I understand your comments on 4WD (though I didn't realise only the rear is braked!), but on the property, and smashed up against a tree, is an old 7 ton tractor that got away from the previous owner on the hill. Was slashing (bush hogging) and turned a corner not paying enough attention. The slasher swung out and hit something, causing the tractor to jump. Tractor got knocked out of gear, and took off down the hill. He was unable to pull it up so bailed/jumped. This wouldn't be possible with a HST (no pedal input = braking), hence why I was thinking they would be safer (though don't know if something similar could happen if a hydraulic hose were to fail).
   / Largest HST Tractor in Aus? #12
It would be helpful to know where, approximately, you/property is located Cobber.
Things are fairly hilly out Pyengana way, where friends run a cattle/sheep + haying farm. WRT the steep inclines, the tyres are fluid 'loaded' and the front tyres (tread-wise) are reversed.
   / Largest HST Tractor in Aus? #13
You can still knock the range lever into Neutral on a HST, the same way that the geared tractors got knocked out of gear.
20 minutes north of Crows Nest (bout an hr north of Toowoomba), QLD.
   / Largest HST Tractor in Aus? #15
Hillside tractors at glass house mountains would be worth a call. Mark their knows his stuff. I have a 90 hp Antonio Carrara used for slope mowing.
Cheers
   / Largest HST Tractor in Aus? #16
That's what I thought. If you need 4wd for the hills, you do need it.... but that's a shame. Nobody wants to pay the price to be in 4wd all the time - tractors are actually 4wd assist rather than full time 4wd because they don't have a differential between front and rear axles. So they are all what we call part-time 4wd because of drivetrain windup stresses. Amplified by carrying a load in the loader for any distance.
And wanting 4wd means that you miss out on used 2wd big 100 hp cabbed Ag tractors - which is where the good deals tend to be even if you have to add a loader for your purposes.
In fact, it seems to me that you should consider two uncommon options. One is to get a used 2wd as above, 50 to 100 hp, put a loader on it, and stay off of hills unless you back down. That way you get some tractor experience without busting the bank. Most of us here have done something like that. You can use 2wd for a lot of work just by applying some common sense. A 2wd ten to twenty year old tractor in good shape with a good FEL and 3pt would do a lot for you. That would be where I'd be looking if my budget were tight but doable.
Tractors in 2wd are not monsters, they just require some care in certain situations. You can even find a special short hill to practice on. I do exactly that. We have a slope at the bottom of a driveway that is dry dirt about 10 feet high and 40 feet long with a flat runout. Enough that even going slowly if I hit the brakes going down slowly the weight transfer lightens the back tires enough to lift them .....whereupon away we go....it's a short ride with a slow safe ending.
Instead of being a teenager doing a rear wheel wheelie on a motorcycle, I'm a 75 year old who has just done a front wheel "standee" with a 5 ton tractor.
The point being that when it happens for real, having practiced anything helps. I'll have some idea of what is happening and what to do.
Also, once you really do lose control going downhill it's a lesson that tends to stick. I'll bet everyone reading this remembers their own experience.
Another great choice but expensive $$ would be look to a different market. Look at the upscale models like the Antonio Carrera that Roygul uses. Some of the European models are light years ahead of the tractors that are common to the USA part-time farmer market. Much more sophisiticated tractors with things like full time 4wd, 4wheel brakes, and suspension! We hear about them over here but don't know much about them. The USA is still 3rd world in tractor technology. Those European models are probably too expensive, but worth checking out.
A third option is a medium hour used but usable TLB like the JD 310. Case makes one too. They don't have a 3pt, but the market for these is pretty steady. They are great loader/backhoe machines. Particularly if you add a thumb. I put this as a last option because although it is a good for some, you do need to be a professional mechanic to evaluate if a particular used machine is worth the price. It needs a professional survey. And also you need to be a mechanic to keep it up. Those mechanical needs makes this option the very last choice for most user, even though the machine itself is a decent choice. The only way it makes sense if if you just stumble on a really low hour TLB maybe from a church or local school district. That happens, so do look. Stay away from commercial use machines and far, far away from used rentals.
Luck,
rScotty
   / Largest HST Tractor in Aus? #17
Tossing out as a muse: perhaps a telehandler? (low center of gravity; long reaches; can do loader work; pretty industrial; high flow hydraulics available; four wheel steering)
   / Largest HST Tractor in Aus? #18
Hello Strev, some suggestions for you to think about.
1) At this size of operation you will need to go full size now, to avoid having to trade up later. NOTE as your experience grows you always get mission creep.
2) look in the 90 - 120hp range. this is the volume part of the market with the best range of choice. There are only 4x4 in this size as the market for 2wd is nonexistant.
3) @90 hp you have a weight range of 3.8 t bare cab tractor. then you add loader and ballast. @ 120 hp you have a weight range of 5.0 t bare cab tractor, to 9.5 t with loader and ballast. At these weights you can run and carry a large rotary slasher or heavy cultivation equipment. I used JD weights as they are representative.
4) It is cheap peace of mind to HIRE a tractor mechanic to look over a tractor.
5) saftey: some tractors when in 2wd will, under brakes switch to 4x4 then when braking stops drop back to 2wd automaticly, others don't.
: Slopes, set the rear wheels to the widest setting for stability. HUGE difference in "feel" and in the positive effect on your confidence. Alternative: DUAL wheels. Stability and traction.
6) Use contractors for the large jobs as they have the gear and are more cost effective. Also you can get a smaller/agile/cheaper tractor leaving more budget for back blade ($10k nz$ for hydraulic everything and tail wheel, to maintain tracks.), bale feeder, slasher, tray, and trailer (6-8ton tandem axle, as more stabile on slopes).
front end loader : DEFINATELY get 3rd service (operate bale clamps, log fork etc)
7)Your son is right about spending on a good tractor as it will be your office.
Good Luck
   / Largest HST Tractor in Aus? #19
Needs to be a tractor, and needs to do a range of things (which I realise will be a compromise for many tasks). Just bought 350 acres for beef cattle, and to put it simply the place is a mess. There is a whole heap (maybe 20 acres, but spread out) of lantana to clear on undulating ground. The previous owner had a dozer with a stick rake in there (did the flat bits), leaving large piles of soil, rock and lantana in many places which I'll want to gradually sort out (seems there was a lot of 'blade' in the stick rake, judging by the amount of soil collected). There are fixes to eroded tracks needed, and filling in or smoothing out of eroded gullies. Large heavy logs and rocks around the place to move.
There is also the usual farm things such as slashing (or bush hogging as you seem to call it on here), but the cattle will do most of it. Might pull a no-till drill at some point in time. Perhaps some small contour line building, but not the ideal machine for it. Don't plan to get into haying commercially, but not sure if I might end up doing something for myself.
Have looked at the tractors in the size of the TYM T503 and Kubota MX5200, but are a little concerned they might be undersized - like digging a hole in the ground with a tooth pick... Some of the property is steep. I see HST as safer on the hills, and for my son to drive, and easier when operating the loader. But may need to go to wet clutch shuttle type gear transmission. As my 16 yr old said to me Sunday when I showed him over the place for the first time (and being surprised by the amount of work it needs) "Dad, you are going to want to get a nice big tractor, because you are going to have to spend a lot of time on it...!".
Since you plan to raise cattle and unless your grass grows year round, you'll need to do some haying for yourself. I do not raise cattle, but my neighbors do and I took courses in cattle management, one thing they emphasized was that a cattle rancher is first and foremost a grassland manager. You need good quality grass year 'round for your cows. It seems to run about 35# hay per day per cow (cow with calf is more). So, as you're looking at tractors, also check out what is available for making hay and get a tractor that is capable of handling that equipment as well.
   / Largest HST Tractor in Aus? #20
Right on. As far as prepping the land for grass and cows I'd no more do that than my own dentistry. Ask around at the neighbors. Throw a get-together party.
They know more about what you need than you do, will admire you for asking, and they already have the equipment to do it with know how. Maybe they even have spare hands to run it. There's always the problem of finding paying work for extra hands and kids during downtown. You could be a good solution.
Using neighbors is much, much cheaper in the long run. Plus you are going to need them. Get the County Ag extension service involved too. There are some nice grant programs available.
And ask the neighbors what tractor you should be looking for while the land is being mended. Compare their ideas to what we know here on TBY. That way you get the best of both groups. You've go time. That will take a season or two at best.
In the meanwhile get yourself a 4 wheeler or medium cheap small USED 4x4 PU with a box on it for inspecting the work on your land. That's a full time job too. Put some cold drinks, spare gloves, and decent tools in the bed box. Enjoy.
rScotty
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
SCAN TO RECEIVE TEXT UPDATES (A58375)
SCAN TO RECEIVE...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
2006 USH BOAT & 2012 TL (A56859)
2006 USH BOAT &...
UNUSED SDLANCH HYD MINI THUMB CLAP7P (A57193)
UNUSED SDLANCH HYD...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2011 Ford F-150...
