Largest Rotary Cutter used with BX?
   / Largest Rotary Cutter used with BX?
Thanks to all for the replies and info.
I do have a FEL that i would use when using the rotary cutter.
I didn't bother getting front weights. I plan on filling the tires and worse case loading some ballast in the FEL if i am still a little light when i use it.
   / Largest Rotary Cutter used with BX? #12
There you go, 5-80 lb sacks of redimix concrete in the bucket will keep the nose down. I suppose a big scoop of wet sand would do it too.
   / Largest Rotary Cutter used with BX? #13
I hope you like your dealer, Botabound. I see a bunch of your money going to them soon to either fix your tractor or replace it.
   / Largest Rotary Cutter used with BX? #14
Any chance you could quantify or at least qualify the underlying premise of your comment? My curiousity stems from a long list of "things a BX can't do" from folks that don't [currently] own one but, an even longer list of BX owners that have actually done most of those things with many hundreds of hours and no probs. But, one never knows. I think this is new territory. Maybe you have info that could save us BX owners from future probs.
   / Largest Rotary Cutter used with BX? #15
My .02.
I have a 60" Bush Hog Razerback light duty rotary cutter that I use with my BX24. and used previously with a BX2230 and an International 300 before that.
It is used to cut an old hay field that is approx. 6 acres. It is fairly smooth rolling land. The tractor does an outstanding job, never bogging in very thick, tall weeds/grasses/brush.
Blades sharp, loader on, no problems.
For this intended use this combo does a great job.
Can a larger, more powerful machine cut Faster, sure.... Would I reccomend this combo to clear rough land of small trees and heavy unknown brush?....Nope.
Can anyone destroy a tractor by being ignorant or foolish? You bet.
That's why this forum is so valuable. You can learn from others expeience.... as long as they actually have that experience.
   / Largest Rotary Cutter used with BX? #16
Homebrew - as an owner of a BX2230, I am confident in my statement.
I tried a 60" brush cutter on my tractor. Yes, it would spin. The lack of a clutch peddel to "feather" in the ingagement was a problem, which I believe would have lead to at least premature wear of the PTO mechanism if not failure. Anything larger than 12" high grass would bog the motor (from PTO speed - wide open) and cause much laboring of the tractor, traveling slowly in low range. I don't believe that any heavier material would have been cuttable. That was with 19 PTO hp. A BX18xx has 15 at the most.
Will it work at all? Sure. Will it last long? I doubt it. There is a huge difference between a 48" and a 60" brush cutter. The BX is a very capable little machine, I never said otherwise. This is asking too much of the unit in my opinion.
Similar to the statements like, "My 1/2 ton pickup will haul a 20,000 lb trailer." Sure it will, once or twice.
   / Largest Rotary Cutter used with BX? #17
AV8R,
I would never discount your experience as untrue.
I must have a Super Bush Hog or Magnum BX because my experience is the opposite.
I usually wait until the field is "dog high"...which is when I can't see the Chesapeake Bay Retriever anymore, to cut. Always 3' plus. Sometime it is over my head. 6' plus. I certainly don't go fast by any means. Probably set the cruise at 2-3 mph. Never had a problem..
All I can guess.. and thats all that it is... perhaps the cutter you used had dull blades, wasn't set up properly (angle of cutter front to rear), in disrepair or a combination of two or all.
As for engagement of the PTO. I set the RPM at 16-1800, feather the lever and find engagement perhaps a bit more abrupt than the MMM. Never so violent that damage may be done to the tractor.
I don't experience any stress on the machine and would not compare use of this cutter to your "My 1/2 ton pickup will haul a 20,000 lb trailer." analogy.
2017 FORD F-550(INOPERABLE) (A55745)
2017 FORD...
MD ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
MD ELECTRIC GOLF...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
2012 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTN6 LIGHT TOWER (A55745)
2012 WACKER NEUSON...
EZ-GO Electric Utility Cart (A55853)
EZ-GO Electric...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
