lawn tractor wiring help
   / lawn tractor wiring help #22
How did all the earlier suggestions test out?
I think you are going to need a meter or equivalent(buzzer, light probe, etc.).
It is not clear to me, after the "click", did the starter engage? Did the motor turn over?
My multi-meter is going wacko for some reason. It acts as if the leads aren't even attached, the readings flucuate up and down. The solenoid clicks really loud, but the starter does not engage. Thanks. The preceeding tests weren't working because for some reason the old solenoid just quit. It no longer works
   / lawn tractor wiring help #24
Sounds like we should try to get the start circuit working. We will need a way to verify voltage. I recommend getting a 12V lamp with alligator clips. Verify it works with the battery.
With the battery connected, connect the lamp between ground and the input terminal of the solenoid. If the light burns, this verifies that there is voltage on the input of the solenoid. This is good. If no light, we have figure out why.
Next find the large wire coming from the starter to the solenoid post. Connect the light to ground and this terminal. The light should NOT be on. Now engage the solenoid (loud click) with the key (or however you do it). The light should come on. The starter should turn. If there is NO LIGHT, there is a problem with the solenoid. If there IS A LIGHT and no starter turning, there may be a starter problem.
Let us know how this test comes out.
Nevermind...I got it to work!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif Ended up going into a different dealer...JD. If the customer service there isn't considered 100% dedication, I truely don't know what is. They have got to be the nicest people anywhere! Totally met my expectations and then some! Definately purchasing from them in the future! Thanks for all the help though...PS, does anyone know if an aircooled briggs reaches 400+ F? thanks
   / lawn tractor wiring help #26
If it does, it going to be a problem. I have never measured, but one would hope for around 325 +/- 25 degrees F. The plus side would be at full output.
Komatsu WA180-1 Wheel Loader (A47477)
Komatsu WA180-1...
2015 John Deere 544K Articulated Wheel Loader (A52377)
2015 John Deere...
BUYERS PREMIUM & PAYMENT TERMS (A54313)
BUYERS PREMIUM &...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
Informational Lot - Financing (A53473)
Informational Lot...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
