Lawn Tractor won't start after being turned off ?
   / Lawn Tractor won't start after being turned off ? #1
brin
Super Member
Georgia - Mt. Vernon by The Store just 5 miles eas
I have a 20 HP Murray Lawn Tractor and lately in has backfired when I shut it down and then will not start for a long time after shutting it down. It runs fine up until the shut down and then won't start again. I have checked the air cleaner and it has clean gas. I did not go into the carb since it ran fine and has been running fine. I do the service on my tractors but his has me baffled..I am wondering if it could be the fuel filter...but since it ran fine I kinda doubt that. Any thoughts will be appreciated. Thanks
   / Lawn Tractor won't start after being turned off ? #2
Any spark ?
Will it try to run with a shot of starting fluid ?
   / Lawn Tractor won't start after being turned off ? #3
Try to run down why it is backfiring, and you may find out why it is not starting.
Checked compression? Right after back firing, and then a "long time" later. This may give you a clue as to rings or valves.
   / Lawn Tractor won't start after being turned off ? #4
I have a few motors that have been doing the same thing (Honda GS160 on a leaf vac and Yamaha 250 atv). I've associated it with using 15% ethanol fuel. Put a new spark plug in them and they run just fine after that. Go figure....
   / Lawn Tractor won't start after being turned off ? #5
Does your engine have a fuel shutoff solenoid (which is supposed to eliminate backfire on shutdown)?
May also be an exhaust valve adjustment issue, ie lengthen when heated & don't seal enough to allow restart untill cooled. MikeD74T
   / Lawn Tractor won't start after being turned off ? #6
Do you smell gasoline when trying to restart? I'd sure pull a spark plug to see if it is wet as zzvyb6 suggested. Sure sounds like a flooded engine to me. The backfire you are hearing might be because of a flood of fuel on shutdown. It might even indicate that your float valve is not seating properly, especially if you don't have a fuel cutoff solenoid as MikeD74T suggested.
   / Lawn Tractor won't start after being turned off ? #7
I have a B&S 14 HP twin, does the same thing after running for a while. I lose the spark whenever the magnito gets hot. It won't happen when it's running, since the air goes past the magnito before cooling the cylinders, but if I shut it off when the engine is HOT, the heat from the cylinders effects the mag and no-spark for 30 or 40 minutes.
   / Lawn Tractor won't start after being turned off ? #8
do you have the model # of the engine; that would help
   / Lawn Tractor won't start after being turned off ? #9
Not sure it will help on yours but do you let it idle and cool down before shutting it down?
Topstrap
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
UNUSED JCT 72" HYD VIBRATORY PLATE COMPACTOR (A54757)
UNUSED JCT 72" HYD...
1991 GMC TOPKICK CHASSIS TRUCK (A54756)
1991 GMC TOPKICK...
2016 Peterbilt 567 Tri Axle Dump (A47477)
2016 Peterbilt 567...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
Parker Gravity Wagon (A50775)
Parker Gravity...
