Lawn Tractor ?
   / Lawn Tractor ?
Thanks for all the comments. There appear to be good options out there. Yesterday, I took a good look at the old Snapper frame and could not find anything broken or severly worn (the motor is shot). I talked to dealer who will sell me a new engine for about $400. This may allow for a cheap way out of the lawn mower replacement problem and allow for other expenses (my wife has other priorities). I have just never considered replacing an engine on a lawn mower before. John.
   / Lawn Tractor ? #12
I can only tell you what my experience has been.
I bought an ugly green and yellow Yard Man four years ago for the simple reason that it was the only hydro mower I found that my 13-year old daughter could reach the pedal on. My neighbor and good friend bought what I really wanted, a John Deere, the same year. We both mow about 1.25 acres. Mine is 17-hp twin, his 15-hp single. Mine 42" deck, his 38" deck. Mine has pressure lube with filter and I may be mistaken but I don't think his does. Both are hydro. I gave $1600, he gave more than $2000. My blades cost half what his do. I have had no repair cost other than blades due to hitting a stump. He has bought blades, muffler, starter, a switch for pto, at least one bearing on the deck, and now the seat is coming apart. A new seat cost so much that he is sitting on a foam cushion when mowing. I have been out $0 on repair, except for blades, and he over $500. My mower has been available for use any time that I wanted it. He has borrowed mine several times while his is in the shop. This is not what we expected when we bought our mowers. This may not be typical for the Deere or Yard Man, but, based on my experience I would buy another and I suggest you look at one of these mowers. I have seen them advertised for $1500.
Stay away from Craftsman. I have owned them and had good luck but know three in the neighborhood who have had bad luck with 3-4 year old mowers. They were told by the repair men that some models had major problems. One guy finally took his back to Sears and demanded his money back (don't know how that turned out). They may have the problems solved by now.
As for replacing the engine on the Snapper, been there, done that on my mothers. Expect to replace everything else, clutch wheels, axle, belts, etc. within a couple years at the most. We used one junker to keep other 'good one' running for a while until it got to the point we were working on it more than using it. Eventually convinced her that she had spent enough on the old one to buy a new one and still didn't have anything to mow with. Of course she bought a new Snapper exactly like the old one because she already had all the spare parts. She mows around five acres weekly and is 78 years old.
You can get a gem or a lemon in any brand. Dealer service is the deciding factor to a lot of people but never seeing the dealer after buying is the best.
Good luck.
Smith
   / Lawn Tractor ? #13
I would also recommend the Garden Web site in addition to this one but for the spamming and flamming and the current JD vs box store tractors flame war raging there now. I also just suggest lurking there till the war subsides at which point you can ask something innocent like---Is a Craftsman any good? or even better---why would anyone buy a Deere when there is Kubota?----then sit back and watch a melt down!!!! /w3tcompact/icons/shocked.gif . Now I am only kidding so please do not answer those questions here--just being humorous /w3tcompact/icons/smile.gif . The site does have some good info and knowledgeable regualar contributors. It also has a lawn and yard/garden care site and a small engine site like for chainsaws and stuff like that. J
   / Lawn Tractor ? #14
<font color=blue>Stay away from Craftsman</font color=blue>
And I just bought one./w3tcompact/icons/frown.gif/w3tcompact/icons/laugh.gif 42" with 21.5hp Briggs, pressure lube and filter, hydro, etc. Only mowed a couple of yards a couple of times with it and can't complain, but it's too new to see how well it'll hold up. I would prefer the foot hydro to the hand lever I have (and a friend has a Deere with the hand lever also), and I would prefer an hour meter which this Craftsman does not have, although it does have an ammeter.
Incidentally, there was a thread awhile back about disconnecting safety switches. When I had a Cub Cadet with the electrically engaged PTO, it would not mow in reverse until I got that safety switch disconnected and the dealer told me it was "illegal" for them to disconnect it, but now this Craftsman is a manual lever to engage the blades, so it mows forward and backward with no problem. Of course the manual does say, Do not mow in reverse unless absolutely necessary. Always look down and behind before and while backing./w3tcompact/icons/laugh.gif
And on the Cub Cadet I also had to disconnect the seat (operator presence) switch because the engine would try to die if I just leaned to one side. On this Craftsman, I can lean either direction as long as there's some weight on some part of the seat and it never stutters, so I don't need to disconnect it.
   / Lawn Tractor ? #15
Buy a used JD-318. Use it until the motor burns up then buy a new Onan engine and you will never need another ridding lawn mower for 20 or more years.
   / Lawn Tractor ? #16
I have a 1978 John Deere 65 and a 1989 John Deere RX 75 (inherited both). I have done nothing to the 65 except for belts, plugs and the like. My father used it to mow cemetaries and schools for 12 years. It's still going. The Rx 75 hasn't seen that kind of use, but I haven't had any problems with it (knock on wood). The spark plug on it is a son-of-a-gun to get out though!
   / Lawn Tractor ? #17
I have a Sears Garden Tractor that is doing very well for me.. No I haven't had it long, but it is taking all I can give it on our 3 acres....
I bought it one year used with the cart.
20hp with 46" deck and was able to bush wack a whole meadow no prob.... No they are not as "tough" as a $4000 tractor, but for mowing and good work they do great.
Go for a drive and you will see plenty of people out on there 6, 8, or 10 year old Craftsmans in my area. Just do the proper maintenance and you are set.
Good Luck with your choice...
Curtis
   / Lawn Tractor ? #18
I forgot to mention: My Dad replaced the JD with a new Craftsman!!! He seems to like it.
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2001 MACK CH613 KILL TRUCK BOBTAIL (A53843)
2001 MACK CH613...
