Laying Pipe
/ Laying Pipe #1
WVBill
Usa
Sold my Kubota B6100 when I moved to WA
I know this topic has been "done" before - just wanted to share pictures of my project yesterday evening. Took about 2 hours start to finish to lay almost 400' of 3/4" black poly pipe in 2 runs.
Pictures part 1 attached.
/ Laying Pipe
Laying Pipe part 2
Pictures part 2
/ Laying Pipe #3
Re: Laying Pipe part 2
Nice place you've got there WVBill. So all of that poly pipe you put in was for watering the outlying areas? I am going to need to do something of that nature eventually. Are you just hooking up outdoor spigots to the ends of those pipes?
I'm not much of a plumber so I get easily confused while working with water.
/ Laying Pipe #4
WVBILL
Generally, I don't like to use mechanical implements when laying pipe. I do , however, sometimes have dinner at a fine restaurant and have a bottle of wine.
Sorry, I couldn't help myself.
RonL
/ Laying Pipe #5
Nice job. I have a similar project to do. What type of plumbing fittings did you use to hook the poly pipe to the outdoor faucets? How deep is the pipe?
I want to just have those frost free faucets coming out of the ground at various intervals. Looks like a subsoiler might do the same thing as the rig you have there.
/ Laying Pipe
I haven't finished plumbing yet but I bought 3/4" barb - to - 1/2" fpt "el" fittings that I'll put at the end of the run. Then a 24" piece of 1/2" galvanized pipe will rise out of the ground with a faucet on top. I'll sink a 4' green fence "T" post into the ground right next to the 1/2" pipe riser for support.
I suppose I could skip the galvanized risers and just run the black poly up the support but 1) I wasn't sure about the UV resistance of black poly and 2) I didn't want to have to worry about hitting it with the weed whacker blade.
The poly pipe is only about 8" deep - doesn't run under any vehicle traffic areas. I'll blow it out with compressed air each fall.
On the supply end I'll add a npt - to - hose converter to the current outside sill cock and use a courrigated copper pipe to connect to the galvinized riser pipe. This way, I'm not altering the house's plumbing so no permits/inspections/etc. are required.
/ Laying Pipe #7
WVBill,
<font color=blue>On the supply end I'll add a npt - to - hose converter to the current outside sill cock and use a courrigated copper pipe to connect to the galvinized riser pipe. This way, I'm not altering the house's plumbing so no permits/inspections/etc. are required.
</font color=blue>
Could you explain this a little more. Sorry for my ignorance. That is exactly what I'm looking to do (I think).
/ Laying Pipe #8
Bill
They are a great tool hey !!
I can only use mine when the ground is soft, and have to cut the trench first like you say, then go back and lay the pipe in another pass.
I laid 400' of 1" pipe no worries.
My pipe layer has a much larger diameter pipe than yours and is supposed to lay up to 1 1/2" pipe.
Well the other day I tried to lay 1 1/4" pipe and it kinked all the time.
It was a cold day and I didn't have a ROPS or a helper so couldn't get the pipe nice and high like yours but I was dissappointed none-the -less.
I doubt if I could do 1 1/2" - It is way too rigid for the layer I think.
Cheers
/ Laying Pipe #9
Just a compliment on such a nice place and such great photos with text... First class!
/ Laying Pipe
tdenny: I used this set up on the other side of the house. I'll take a picture tonight and post it with explanation.
Niel: It was 90 degrees F the day I laid my pipe and I set it out in the sun early in the day so it was good and warm. Funny thing: it was crimped on both ends of the 400 foot roll at the factory and when I went to cut it just prior to laying it the air pressure had built up from the heat of the day and as I sliced into the pipe the air release was quite a surprise!
Even on a hot day, I don't think 1 1/2" pipe would be flexible enough to make it through the bend of a pipe layer tool like ours.
emery - thanks.
/ Laying Pipe #11
WVBill, Where do you live, How deep did you run the pipe? I only ask because I am looking into laying some water pipe but it has to be down about 18" due to frost. Are freezing winters a problem for you? If so how do you plan on draining the pipe?
tjl
/ Laying Pipe
tjl:
I'm in the Eastern Panhandle of West Virginia. Yes, freezing in the winter is an issue. The pipe is only about 8 - 10" deep and would freeze in the winter. Last summer I laid 125 feet of regular PVC pipe out to my barn about 10 - 14" or so deep. In the fall, I used my air compressor to blow the line out. This spring - no leaks so it worked. I plan to do the same thing on these black poly pipe runs. I guess one could also gravity fill the pipes with a non-toxic anti-freeze. I figure 4.13 Gallons to fill 180' of 3/4" pipe.
pi x radius squared x length x gallons per cubic inch = gallons
3.14 x .375 x .375 x 2160 x .004329 = 4.13 /w3tcompact/icons/clever.gif
/ Laying Pipe #13
Thanks Bill,
I will keep an eye out for your pictures. That definitely is a nice looking place you've got there.
/ Laying Pipe #14
good looking place!! is that the B6100 you went to california and brought back?? i have a subsoiler with a pipe welded on the back to do exactly the same thing, around here 6-8 inches and it won't usually freeze, but the subsoiler will put it down deeper than that when needed.
heehaw
/ Laying Pipe
tdenny: Attached is the picture that should clarify the hook up.
heehaw: Yup. That's the B6100.
/ Laying Pipe #16
Thats not a water pipe duct taped to an electric conduit is it?? /w3tcompact/icons/grin.gif
/ Laying Pipe #17
WVBill,
Thanks much for the picture. That look simple enough. I have a similar setup with the soaker hoses I use in my front flower beds.
Mine is definitely not as sophisticated as what you've got there. I think I'm going to use your idea to put some water pipe out to my goat's house as well as other areas.
/ Laying Pipe
Dang, Inspector - I thought I airbrushed out all the code violations. /w3tcompact/icons/wink.gif
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
New/Unused AGT Industrial SDA-140T Track Loader (A65583)
New/Unused AGT...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
2007 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRK (A64277)
2007 FREIGHTLINER...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
