Leaf Vacuum
   / Leaf Vacuum #1
Dutchman
Bronze Member
Somerset County, Western PA
CC 7265
I'm looking for a source of parts and perhaps a knowledgeable reader may point me in the right direction. I want to build a leaf vacuum. I haven't made up my mind whether I want a PTO driven one or a stand alone one that I can mount to a hitch assembly on my truck (I have a 16hp engine from an old lawn tractor).
I’ve seen the end product at www.trac-vac.com (click on the PTO vacs or the truck loader ones). The part I’m looking for is the air turbine that actually provides the vacuum, leaf reduction (to a degree), and the exhaust to the container.
Has anyone done this or have any pointers?
Many thanks.
   / Leaf Vacuum #2
I picked up a Craftsman/MTD 5 hp chipper/shredder last year that I have been kicking around the idea of making vacuum out of. Maybe you can find one of these cheap and use the turbine for your project.
Doug
   / Leaf Vacuum #3
Dutchman,
I'v been looking for a turbine too for about 2 years with no luck. I refuse to pay 1000 plus dollars for a TracVac or similar vacuum product when I can make one for less than half.
   / Leaf Vacuum #4
Dutchman,
Woodworking shops use large vac systems to capture wood chips, etc. produced by the saws, planers, and other tools. There are several producers of the "fans" to create this vacuum, but I have a 3hp unit I purchased from Grizzly. These units typically use 6 inch pipe for pickup, but larger sizes are available. You might browse some of these forums and find something.
http://talk.woodmagazine.com/woodtalkindex.html
http://forums.taunton.com/tp-knots/
http://theoak.com/wwwbb.html
Hope this is helpful.
   / Leaf Vacuum #5
HI,
I HAVE A TRAC-VAC. WHEN MY BLADES ON THE TURBINE WEAR OUT, I GO TO THE LOCAL DISTRIBUTOR AND BUY A REPLACEMENT . YOU CAN ORDER THE TURBINE HOUSING ALSO. IT BOLTS UP TO A 5 HP BRIGGS, BUT COULD BE ADAPTED TO FIT OTHER ENGINES. THE SHAFT ON THE TURBINE IS 3/4 IN. YOU CAN ALSO GET PLASTIC IMPELLERS . THE TURBINE INLET AND OUTLET, ARE USUALLY 6 IN, OR 8 IN . YOU CAN EITHER BLOW INTO A PICKUP BED OR A COVERED WAGON. OR A 55 GAL BARREL LIKE MY TRAC-VAC. ON A LEAFY YARD, IT FILLS UP REALLY FAST. HOPE THIS HELPS.
J.J.
   / Leaf Vacuum #6
This looks nice as well....you can empty by reversing flow
http://www.cyclonerake.com/index.html
The Commercial unit is $1295...I think you would be hard pressed to build something as nice as this for less...
Of course I could be wrong /forums/images/graemlins/smile.gif /forums/images/graemlins/grin.gif
   / Leaf Vacuum #7
I purchased one a three years ago. It works well as a vacuum, but it doesn't empty as easy as they advertise. One problem is that the zipper jams and the snaps that hold the bag to the chute pull off and no replacements are available.. Another problem is that the grass clipping will jam the top plastic screen and their solution to this is to supply a toilet brush so you can clean it each time you empty it. If mine is any indication of the quality control that they put into them, I would say "STAY AWAY!". Under warranty, the bag had to be replace twice, threaded parts were not produced properly and wouldn't thread together and the bag falls off the chassis when you dump. They have since fixed this by adding a brace, but they don't feel that any manufacturing design flaws should trigger a recall. As I have said, when it works, it works well, but it has had more than its share of manufacturing and design defects that I have to deal with. The discharge chute to bag mounting snaps that I need are no longer available. Most companies will have parts for a unit that is 3 years old, but not Cyclone Rake. There way of dealing with manufacturing and design defects is to ask you to pay $ for any design upgrades after you paid $1200 for the unit..... Their warranty is one year, however considering the problems with mine, I wouldn't suggest you buy one.
   / Leaf Vacuum #8
Hi Junkman,
I have no doubt you had a real bad exprience with the CR..
You actually are the first negative comment I heard.
Thanks for the heads up, I wont be purchasing this type of unit this year. I have my hands full with the other investments and space. But if not CR whats another brand to look at??
Ducati996
   / Leaf Vacuum #9
I've been thinking if I could modify one of these
that we have to be more of a vac/shredder with the hoses and a collection box/trailer.
I would have to remove the big chute and create a flange for the 6" hose to connect. And seal/plug the little limb chute, and modify the outflow flange.
To bad they don't have a conversion kit....that I've seen... /forums/images/graemlins/smirk.gif
As it is, it blows the shredded leaves all over the place and if you put the little bag on it to collect the leaves, it fills up in about 2 minutes. Also, the leaves tend to clog in the chute if you don't feed them in just right. We haven't used it for 2 seasons now, because it's so user unfriendly.
We use out backpack blower to pile the leaves up in 4-5 areas then use the this thing to shred them up. It does a good job, but it's not as easy as a hose/shredder/box system would work.
gary
   / Leaf Vacuum #10
If you were to purchase one of the newer models, I doubt that you would be having the problems that I have because they finally have addressed all the short comings of the previous designs. What I find discouraging is the fact that the manufacturer doesn't seem to think it important enough to send corrective information and updated parts to the purchasers of their products that have had continual problems because of the poor design. The changes were done to address failures, not improvements to make them better. Failure by design should = no charge for replacement parts in my opinion... I also can understand that they can't warranty a product for life, but this isn't replacement of a part that has worn out, but was a defective design from the beginning. It is not like the machine is 10 years old. When they replaced parts under warranty, they were the same defective design and they failed just like the original. Then they redesigned the entire part, but want to charge for the replacement of what is defective from the beginning. I don't think that this is the way to do business and develop a good customer relations for future sales. Possibly they feel that if you bought one, that you will never buy another. If the way that they treat past customers is any example of how they will treat future customers, then I still say "stay away!".
STORAGE FEES (A52576)
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
1264 (A50490)
1264 (A50490)
2020 Westfield MKX 100-83 Auger with Swing Hopper (A52748)
2020 Westfield MKX...
1973 CATERPILLAR 988 LOADER (A52576)
1973 CATERPILLAR...
2018 Ford F-150 Pickup Truck (A51692)
2018 Ford F-150...
