Leaking Axle Oil Seal
   / Leaking Axle Oil Seal #1
endless
PA, Susquehanna
Iseki TS3110F, Allis Chalmers WD 45
The oil seal on the rear axle on my 3510F is leaking. I see in the parts manual that the axle is held in by some sort of spanner nut on the inside. Can someone tell me how big a job it is to replace the seal or perhaps there is another alternative?
It is leaking enough to drip spot the wheel rim.
Thanks /forums/images/graemlins/confused.gif
   / Leaking Axle Oil Seal #2
You can run the unit and keep adding oil. (Let that be your contribution to dust control) OR you can get yourself a shop manual. After reading the shop manual you can determine whether you can tackle the job yourself or not. Big leak or small it needs to be fixed!
2004 KENWORTH DIGGER TRUCK (A50854)
2004 KENWORTH...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
2013 GALYEAN 130BBL VAC TRAILER (A50854)
2013 GALYEAN...
Swamp Buggy (A49346)
JOHN DEERE 9650 COMBINE (A51243)
JOHN DEERE 9650...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
