Leaking Battery Acid & Paint Damage
   / Leaking Battery Acid & Paint Damage #11
One other possibility is to use a plastic box like is used for boats but I never looked close enough to see how the box would fit. I guess either way, any leaking acid is no good for the tractor or the battery.
I have the CT235 and use it on hillsides also, only 25 hours on it so far. I guess I should replace with the sealed battery also, don't want to deal with the leaking acid mess!
I picked up a sealed Diehard at Sears, but I'm still replacing acid damaged parts & bolts and repainting the gril. Not what I have time for in the middle of projects. Peace of mind with a sealed battery!
   / Leaking Battery Acid & Paint Damage #13
the leaking battery sucks, especially considering the price of the tractors. would it have killed bobcat to put in a sealed one?
   / Leaking Battery Acid & Paint Damage #14
I'm not sure what Bobcat's battery policy is but the Kioti's are shipped in a crate with the wheels and I think seeing the rops and steering wheel off and without a battery. That's how mine arrived at the dealer six years ago. It's the Kioti dealer's responsibility to mount the tires, etc. and put in a battery. They also do the mounting of the fel brackets and hydraulics because it's considered an add on and not everyone gets a fel. I'm sure battery price comes into play for dealers. Maybe when buying a tractor, either brand, a battery type would be a negotiating point.
   / Leaking Battery Acid & Paint Damage #15
i would agree they should provide you with the battery you want
I agree, but the dealer wouldn't go for it. I didn't want to argue, so I just went & bought a new one.
   / Leaking Battery Acid & Paint Damage #17
Actually, it's not the corrosion that's the big issue.
Leaking batteries are a significant health hazard. It exposes you to toxic fumes, and acid burns.
No dealer worth a **** would sell a tractor with a battery where normal use would cause the battery to spill. And operating a tractor on a slope is normal use. (Unless you're doing barrel rolls with it, which is really not normal.)
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
2003 Big Tex 10PI...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
2020 DRAGON ESP...
